Camera Access
Yepher
Camera Access
Post by Yepher » 15 Mar 2013 19:50
I have this camera
http://www.zwaveproducts.com/Zwave-Secu ... amera.html
How can I access it with Z-Way and my RaZberry?
If you look in the data sheet
Post by PoltoS » 15 Mar 2013 19:50
If you look in the data sheet, you will find that is just an ip cam. there is nothing from Z-Wave in it.
Yepher
Datasheet
Which datasheet did you look at.
I have used this witch a couple of ZWave gateways like "MyNexia" and I was able to view it through their gateway.
The datasheet in the site you
The datasheet in the site you posted does not mention it is a Z-Wave device except that it is supported by some specific Z-Wave enabled controller. The camera is a simple IP cam, which is supported by the gateway you have used, but it has nothing to do with Z-Wave. At least we have never seen Z-Wave enabled cameras.
