Command line examples for triggers
remecz
The doc you're referring
Post by remecz » 28 Mar 2013 14:42
The doc you're referring to seems to have been moved here http://razberry.z-wave.me/docs/zway.pdf
Still no mention of .syscommands
As I download it this file is
Post by pz1 » 28 Mar 2013 14:42
As I download it this file is not complete either. After the index several pages seem to be missing. Paragraph numbers are drastically changed. It would be good if they put a date/version number on the frontpage.
The 4 pages file contains a
Post by PoltoS » 28 Mar 2013 14:42
The 4 pages file contains a link to a new one: http://razberry.z-wave.me/docs/zway.pdf
We have splitted h/w and s/w secific descriptions in two files.
It is in paragraph 17. Bue
It is in paragraph 17. Bue too short (we will update it soon). Here is a bit more detailed:
system(command_part1, command_part2, ...), where only command_ need to match one of .syscommands line, and the final executed command in shell would be made from concatenation of all command_partN.
.syscommands should be located in http_root/ folder
But still this document does
But still this document does have an incomplete index of only two pages. The next pages are blank. Then the text starts at page 7.
michap
Please check this here -
Post by michap » 28 Mar 2013 14:42
Please check this here - maybe it helps
http://en.z-wave.me/comment/1461#comment-1461
This information is at odds
This information is at odds with the Zway manual which tells me at the end of section 17.1 (page 66)
system(command): executes an external command in shell and returns [ret code, output]. Command should start with one of the lines in http root/storage/.syscommand
