Aeon Multisensor Inteview failed
holzemile
Post by holzemile » 29 Mar 2013 17:43
I just bought the RaZberry and the Multisensor by Aeon labs. I clicked on "(Re-)include" and pressed the button on the sensor.
The include was sucessful, but it says "Interview is not complete yet. You probably have to wake up the device" (in "Devices configuration") and it doesn't change when I wait half an hour or exclude it, remove the configuration and then include it again.
When I go to "Device control">"Device status" there is a question mark and when I click on it, everything says "Done" except "SensorMultilevel" says "Force re-interview"!
When I click on "SensorMultilevel" there is the following:
undefined: None (15:33)
version: 5 (15:33)
security: false (15:33)
interviewDone: false (15:33)
interviewCounter: 9 (15:33)
sensorType: None (15:33)
sensorTypeString: None (15:33)
-->val: None (15:33)
scale: None (15:33)
scaleString: None (15:33)
while everything is green except "val: None (15:33)" is red!
Do you know how to fix this?
You certainly use older
Post by PoltoS » 29 Mar 2013 17:43
You certainly use older version of RaZberry s/w. Please update it to the version from yesterday. It will work perfectly.
holzemile
Yes, thanks :)
Yes, thanks :)
