Dates and times
mcfanda
Dates and times
Post by mcfanda » 10 Apr 2013 14:23
from device configuration, when requesting data from the associated devices, dates and times are all wrong. The raspberry date is fine, but the devices dates are not. any hint?
thanks
marcello
michap
Contact:
date wrong?
Post by michap » 10 Apr 2013 14:23
What do you mean with date is wrong?
Can you give some sample? So it will be more clear for all others too ;)
The Web UI uses your local
Post by PoltoS » 10 Apr 2013 14:23
The Web UI uses your local timezone to convert server time to local time. Make sure your local time is ok
