Hello.
I have just included a Door/Window sensor from Fibaro and i have no problem reading the state if its open or closed but i have also added a DS18B20 and my question is if it is possible to view the temperatur from the sensor in the included webgui?
What is the right syntax to grab that value with API?
Fibaro Door/Window Sensor
I have a Fibaro sensor multilevel and read it like this...
Isaksson, see below for my device '6' and tempsensor on instance '3'
BestR Walter
http://192.168.10.248:8083/ZWaveAPI/Run ... .val.value
BestR Walter
I had to exclude / include
I had to exclude / include the device after adding the temp sensor. Now I could see both state and temp in the webgui.
@Isaksson,
which z-way version you used ?
i do not have success including my fibaro fgk-101, (i got 2) with z-way 1.3.1 and 1.4.1-rc1.
while my aeon 4-1 multi sensor goes fine...
I had to roll back to version
I had to roll back to version 1.3.1 to get the sensors to work.
Use the "tamper" button on the back to include it, push as fast as you can.
