Wall Switch and Plug In Module Dimmers Status Level Returned Wrong Value
aibojian
Post by aibojian » 22 Jul 2013 07:14
When I am using RazBerry with either Z-Way iPhone app or OpenRemote, I'm getting incorrect value in return.
Ex 1: When I am using slider and selected 60 the return value will either jump to 96 (if it was from 99) or 4 (if it was from 0).
Ex 2: When I click on the ON button (value was set at 99) from value 24, the light will turn on to 99, but the return value is 27.
Wondering if anyone experiencing the same issue and is there's a workaround. Thanks in advance.
PerM
I've seen this as well when
Post by PerM » 22 Jul 2013 07:14
I've seen this as well when POSTing to the Json API. From what I understand, it is the result of the end device reporting a value before it is still executing the command to dim up/down. Subsequent calls to read the value in question returns the correct value.
aibojian
Make sense
That make sense. is there any way to delay calls or when posting commands through JSON API, so it returns the correct value?
PerM
Not that I know of.
Not that I know of.
aibojian
Resolved
I got it resolved by combined 2 commands separated with a semicolon, which polls every 2s
http://RazberryIP/JS/Run/zway.devices[N ... erLevel(N)
there is, but how much time
Post by PoltoS » 22 Jul 2013 07:14
there is, but how much time to wait? dimmer can be told to dim for 1 hour form 100% to 0%. So, how long to wait for?
Good devices have a group to report state changes, so once they have finished dimming, they report correct value themself. Even if it was not Z-Way who initiated the change.
