How to work with door lock VIS_ZM1702 using razberry?
Posted: 29 Jul 2013 17:11
The manual to the lock is quite short and just refers to 'Z-Wave interface controller's instruction' in order to set/reset user codes and schedule. I've guessed this in 'expert mode' - under 'command class user code' - and it seems to work. However the general part - namely to 'lock' and 'unlock' the lock looks really ugly. Namely - there are dozen of buttons instead of just two actual 'secure' and 'unsecure'This door lock doesn't distinguish between 'outside' and 'inside' handles, and so, it have to be masked by xml and hidden in the config.BTW, I see that most of the other features propagated by lock's developer is not supported (yet?) Is any plans to support COMMAND_CLASS_SCHEDULE_ENTRY_LOCK?Also, setting a timeout using DoorLock.ConfigurationSet in demo UI (expert commands section) doesn't work due to 'Internal Server Error'. The UI tries to send the command with only 3 params in the time when it requires 5.
