z-way iOS app not finding razberry
universaldilettant
Post by universaldilettant » 01 Aug 2013 19:37
the iOS App always shows No connection although I can connect through the web-interface. via http://ip_of_razberry:8083/
how do I connect using iOS and what do I need to enter as credentials?
thanks
Username/passwd should be
Post by PoltoS » 01 Aug 2013 19:37
Username/passwd should be empty. Make sure you are in same network (wifi and your LAN). Also make sure to use http:// prefix and port number.
universaldilettant
tried it - but no luck.
tried it - but no luck. anyways the app omits the http:// directly after changing to another field.
tried to put both in the indoor and outdoor server. both reult in the no connection error. I have the feeling that the app doesn't even try to connect as there is no waiting or anything involved...
thanks
universaldilettant
iOS z-way app actually crashes the server
So it seems that the app connects to z-way server on the raspberry but always when I launch the app and try to open the connection the server crashes.
Please provide us with the
Please provide us with the log, server version and may be the crash dump.
