re-act on sensor status change
rgroothuis
Post by rgroothuis » 04 Aug 2013 23:22
Hi All,
Just new to the Z-wave and Razpberry. I really like the Razpberry device and all te available sensors. I'm busy studying the ZwaveAPI JSON interface, still a lot to learn.
I want to create a situation that when a door sensor status is changed some action is taken, for example an email send and a entry logged in a database. I assume I need to do my own programming, make an own application that runs 24/7 that is triggered by the sensors and then takes some actions.
Where to start with such an application? In the documentation I only find javascript/JSON code examples which can be used in web-pages. But the 24/7 application cannot be a web page.
The application needs to run on the Razpberry.
my questions:
- which programming language,
- example code available,
- (other).suggestikns on how to implement this.
Thanks for your support.
Cheers, Rene
hekj
NexaHome
Post by hekj » 04 Aug 2013 23:22
You can use my software NexaHome, then you need not write all program code on your own.
Just create one small bean shell file that calls a script (written by you) when a sensor is triggered.
e.g.
You perhaps have a Fibaro door sensor...
Create a bean shell file.
/home/pi/nexahome/2.bsh
execFile("/home/pi/do_something.sh");
execParam("--door=2");
if (deviceIsOn("2")) {
  execParam("--status=open");
} else {
  execParam("--status=closed");
Henrik | http://nexahome.se
