New Home Automation engine and New UI
Pipistrello77
Re: New Home Automation engine and New UI
Post by Pipistrello77 » 15 Apr 2014 21:19
Hi PoltoS, could you say me if my needs will be covered in any way?
Maybe i dont understand very well how it works LightScene.
In fact, i dont understand very well the way LightScene works :-(
vwirus
Post by vwirus » 16 Apr 2014 22:04
I can see by the state of develop branch that v1.5 is still in heavy development. It's good to see but in other hand master branch wasn't updated for 6 month or so and master is not stable. So maybe there is option for razberry team that you would update master branch with some semi-stable code?
Post by PoltoS » 16 Apr 2014 23:15
We will, but we want to update it with some good code, not a semi-pseudo-working one
vwirus
Post by vwirus » 17 Apr 2014 13:24
PoltoS wrote:we want to update it with some good code, not a semi-pseudo-working one
this is very good point but... current master branch is already "semi-pseudo-working" at least in case of automation engine. Isn't it?
Anyway thank you for your work and reply.
Pipistrello77
Post by Pipistrello77 » 18 Apr 2014 17:05
Hi folks,
at last i decided to make my own modifications to BindDevices, so i have different modules called OffWhenOn, OnWhenOff, etc... There are only little modifications of BindDevices but they permit to have more flexibility (for instance, switch off a light when i switch on other light).
My modifications are "rubbish" (i have not too much knowledge in software development), but if somebody want to see the modification i could send by private message.
Please, could somebody explain to me how it works LighScene with a real use case i could understand?
Regards
Post by PoltoS » 19 Apr 2014 02:40
LightScene creates scene vDev that activates other scenes or trigger switches/dimmers in a particular state. Think of it as a shortcut to a state of several devices.
We think to improve BindDevice to allow invert states of each device in the list. But this will make the module too complicated (at least for dimmers), so we are not sure if this is worth.
Pipistrello77
Post by Pipistrello77 » 19 Apr 2014 22:34
Thanks!
It sound strange the activation of another scene is a mandatory field. Anyway, thanks for your explanation!
About BindDevice.... i understand. My version only works for switches not for dimmers. The code would need a deep review (converting any "active value" to "on" or something similar).
Post by PoltoS » 01 May 2014 03:11
Please look on the new code on github. It has Bindings working (at least cases we have tested ;) and it also have GroupDevices module to group several together and even to invertion of state.
SolarFlor
Post by SolarFlor » 01 May 2014 11:22
Hi PoltoS
What happen to our configuration when we download a new code?
do we lost our configurations, maps, devices?
Is it enought to make a backup and a restore after the loading of the new code?
Many Thanks
Post by PoltoS » 01 May 2014 12:09
you only need to update the new UI folder - have a look on the top of the post how to get the code from github.
your Expert UI settings and devices will be untuched
