Greetings,
I am running 1.5 and noticed that you have to do a manual refresh of Aeon Smart Energy Switch to see the current power consumption..
I am pretty convinced that the issue is the configuration parameters 90, 91 and 92 and 100 which control the update intervals (for example 91 is set to minimum 50 watts to report however no expert UI is present to change these values more in line with my expectation..
How can I change these behaviours?
Aeon Smart Energy Switch Not Updating
Re: Aeon Smart Energy Switch Not Updating
Don't you see Configuration Set form in the Expert Commands tab?
Yes I do and although I set 92 to 1W it does not work.. I can see the message configuration parameter type is not handled in the interface and the values are blank so I can only presume it is not working as expected which is not optimal...
Please see Thread viewtopic.php?f=3422&t=20333
