Strange behaviour in scene+group+bind
Re: Strange behaviour in scene+group+bind
Post by PoltoS » 08 Jun 2014 16:10
Pipistrello77
Post by Pipistrello77 » 08 Jun 2014 18:10
Great. I'm an absolute begginer... i will try.
Pipistrello77
Post by Pipistrello77 » 08 Jun 2014 19:36
Impossible for me.
I was trying with no success to install npm and node-inspector. That works no fine for me. Debugger crash when i was trying to see the console in 127.0.0.1:8080.
After this operations... chrome is not working any more to see home automation UI.... ¿? very strange. I'm removing all npm and node-inspector packages at this momento :-(
pz1
Post by pz1 » 08 Jun 2014 20:46
Pipistrello77 wrote: I'm removing all npm and node-inspector packages at this momento :-(
You may consider to make an image copy of a working SD Card instalaltion before starting a new experiment. Saved me a lot of agony over the past months. I do use Win32DiskImager on my windows 7 machine. There may be others and better ones. I just found this one.
I do cycle 3 cards.
Pipistrello77
Post by Pipistrello77 » 08 Jun 2014 23:28
Thanks... its a good advise that normally i do not follow because i'm lazy :-S
Another clue for my problem. I have noticed that this behaviour only affect to "binary" conditions. If a use a multilevel condition -for intance with a wall-plug with metering- all works fine.
The problem is the condition seems to "match" no matter if the state is "on" or "off" despite i have set the condition to "on"...... but only if i operate the lights using UI button instead of phisical wall switches.
