Congratulations for the new version !
I've just a little problem, I can't access to 8084 port. The page doesn't load.
I've update from 1.4.1 to 1.7.0-rc2 then 1.7.0-rc3 and finally 1.7.0.
I never had access.
Is there a special configuration to do so ?
Can't access to 8084 port v1.7.0
Re: Can't access to 8084 port v1.7.0
It should be installed durin update process. Anything special in the log of installer?
I have the same issues. All UI are available to 8083 and nothing will appear on the screen if I interrogate 8084
I saw nothing special in log files.
After reinstalling 1.7.0 and removing the apache server I had installed (on port 80), a page load on the 8084 port, but asks for a login and password with the following message "z-box". Is this normal? If so how do I connect?
first time it asks you to specify a password. this is ok
Could you please explain what is the utility to access to the port 8084?
I mean I have apache server running on port 80 and I don't wont to remove it as Flo5929 did.
Also I can access to UI on door 8083 so I could continue to do it, right?
For which tasks is fundamental to access the port 8084?
I'm connecting remote using 8083.
I mean using a dyndns link I could connect to all UI by:
http:// ...dyndns.org:8083
Did I miss something?
Service offers a secure reverse proxy to connect remotely to your box.
You may access your home via https://find.z-wave.me, and you don't need neither dyndns nor forwarding 8083 port on your router to do that.
Fantastic!!
Where I can find Z Box ID and how to set a password ?
