Upload image on UI Razberry
Alderaan
Post by Alderaan »
I have a problem when I upload an image with .jpg format for stick up my map. I select it and after there is a white page appears with an incompatibility icon, and later, the default image came back.
I tried with another browser but it the same error.
An idea to resolve that ?
kambis
Contact:
Re: Upload image on UI Razberry
Post by kambis »
I was faced to same problem.
uploading image seems to have a bug.
You can manually copy your desired .jpg file to the folder /opt/z-way-server/config/maps
Now reload the page in expert UI and you get your image shown ;)
cpighin
Post by cpighin »
:) I got the same issue trying to upload my image. My browser was running continuously informing that was waiting for answer from IP ...
Maybe the bug is still there ;)
I copied my image into the folder /opt/z-way-server/config/maps, as suggested by Kambis, and now I can see my image on the web.
Claudio :)
orlando
Post by orlando »
I have same problem. Image don't upload in smarthome ui... how can i fix it? manual copy is not an option, please, i need to fix this basic bug
Isaksson
Post by Isaksson »
Until there is a fix, why is not manual copy an option? Seems like a good quickfix until the issue is closed.
