Custom User Code
islipfd19
Custom User Code
Post by islipfd19 » 08 Jul 2014 22:47
I'm attempting to add custom code to the automation section and I continue to see errors in the log file.
[2014-07-08 15:30:55.406] Scheduling execution of file: automation/update.js
...4-07-08 15:30:55.419] Executing script: function getDataUpdate(sync){
[2014-07-08 15:30:55.443] JavaScript compilation error: SyntaxError: Unexpected
end of input
at automation/modules/CustomUserCodeLoader/index.js:39:13
at Array.forEach (native)
at CustomUserCodeLoader.init (automation/modules/CustomUserCodeLoader/index.
js:34:33)
at AutomationController.reconfigureInstance (automation/classes/AutomationCo
ntroller.js:341:22)
at ZAutomationAPIWebRequest.<anonymous> (automation/webserver.js:542:44)
at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/
request.js:241:30)
at automation/request.js:31:35
at HTTP request:1:1
I've actually copied the code from the API that's available online at http://razberry.z-wave.me/docs/Z-WayAPI.pdf.
function getDataUpdate(sync)	{
 $.postJSON('/ZWaveAPI/Data/'+D.updateTime,handlerDataUpdate,sync);
$.postJSON = function(url, data, callback, sync) {
	if (jQuery.isFunction(data)){
		sync = sync || callback;
		callback = data;
		data = {};
	$.ajax({
		type: 'POST',
		url: url,
		data: data,
		dataType: 'json',
		success: callback,
		error: callback,
		async: (sync!=true)
function handlerDataUpdate(data) {
	try {
		$.each(data, function (path, obj) {
		var pobj = D;
		var pe_arr = path.split('.');
		for (var pe in pe_arr.slice(0, -1)) {
			pobj = pobj[pe_arr[pe]];
		pobj[pe_arr.slice(-1)] = obj;
I don't know much about js but everything seems to be accurate, syntax wise. Does anyone have any thoughts?
pofs
Re: Custom User Code
Post by pofs » 09 Jul 2014 02:41
The code you quoted is client-side (intended for execution in browser with jQuery), but you're trying to use it at server side.
Furthermore, handlerDataUpdate function seems to be truncated in some brutal way.
islipfd19
Post by islipfd19 » 09 Jul 2014 07:38
Do you know or can think of anything that can be used on the server side? Even something along the lines of a PHP script that can be scheduled to run frequently using cron. Basically, all that is needed is a way to query the z-wave switch component requesting whether it's on/off/(or what state it's in if it's a dimmer).
kambis
Post by kambis » 13 Jul 2014 20:37
You might like to have a look on this post:
viewtopic.php?f=3424&t=20528
islipfd19
Post by islipfd19 » 02 Aug 2014 15:48
@Kambis:
Not sure how often you read your own posts...? I've replied to one of your posts where you responded to me in. I was able to figure out the correct syntax to poll for the switch state. I've uploaded the module for anyone to use if they like. viewtopic.php?f=3424&t=20588
kambis
Post by kambis » 02 Aug 2014 16:19
I saw your code in between, thank you for sharing.
