http syntax for dimmer switch Razberry
n4zg
Post by n4zg »
Hi im a bit stuck i am trying to access a dimmer switch with the following url on the razberry module
http://<ipaddress>/ZWaveAPI/Run/devices[4].instances[0].commandClasses[0x20].Set(78)
but not working any suggestions please .
Eric
Re: http syntax for dimmer switch Razberry
Post by Eric »
You should use the SwitchMultilevel command class instead of Basic, so:
http://<ipaddress>/ZWaveAPI/Run/devices[4].instances[0].commandClasses[0x26].Set(78)
n4zg
Post by n4zg »
Thanks for the reply, that kind of works but i have to referesh the page to activate it and it doesnt seem accurate for example i do set 78.. it sets it to 78 then when i reduce it 40 the amount in the interface shows 70, does it need a command to switch it on or off . thanks for the info..
