Websocket Support in 2.0
hecashit
Re: Websocket Support in 2.0
Post by hecashit » 04 Jan 2015 12:06
pofs wrote:
hecashit wrote:Don't work for me in custom JS user files inside Automation folder.
Maybe you should explain more details regarding what and where exactly you wrote.
Your file may be not executed at all, or it is just executed once on startup (when there's no clients connected yet), or hundred of other possible scenarios.
Ok, sorry for previous panic post.
I put custom script file inside automation folder and set in the home automation subsystem.
File have only this code:
test = function() {
var obj = {type: "Иванов"};
ws.push("my.custom.event", obj);
html page scripts same as you describe.
Than i open "localhost/JS/Run/test" and check logs in html page.
My fault that i use localhost/JS/Run/test instead if localhost/JS/Run/test().
When i try to use localhost/JS/Run/test() it start works..
Thank you :)
Appologise my English
Post by pz1 » 26 Jan 2015 14:41
pofs wrote:If you actually need UDP, you'd better refer to @pz1 posts about UDP and OpenRemote. I'd rather write a native UDP sender, but calling netcat in a shell script also works fine.
@Pofs
How would you make this native UDP sender. I don't see any option in the JavaScript language tutorials. Also haven't found a library. I did see some solutions with node.js. Is that what you had in mind?
pofs
Post by pofs » 27 Jan 2015 05:58
@Pofs
2.0 supports native modules, so you can write a C++ library and expose it to JS. And it is quite easy to send an UDP message from C++.
Post by pz1 » 27 Jan 2015 11:28
Thanks for pointing me in this direction. Googled a bit for existing libraries, but those are apparantly out of my league. I'll look around a bit more in the coming days.
Any chance of UDP send support in a future version?
n0ahg
Post by n0ahg » 31 Jan 2015 23:36
pofs wrote:
@Pofs
Please could you point me to the docs and examples for writing these native modules?
pofs
Post by pofs » 03 Feb 2015 21:41
n0ahg wrote:Please could you point me to the docs and examples for writing these native modules?
We haven't documented it yet, but I'll publish a sample library soon. Stay tuned :)
shiphrah
Post by shiphrah » 09 Feb 2015 12:40
I'm also VERY interessted in support for native modules! Any updates/infos for this yet?
Post by pz1 » 09 Feb 2015 18:02
pofs wrote:2.0 supports native modules, so you can write a C++ library and expose it to JS. And it is quite easy to send an UDP message from C++.
I did notice this issue in Github: Make TCP/UDP module for JS. Hope it is not a very long term goal ;)
dolpheen
Post by dolpheen » 10 Apr 2015 18:30
Is there any info on websocket support?
I want to use IR remote control server to publish events (via EventEmitter on devices collection) in order to control widgets.
So, then we will be able to use any standard IR controls to control home automation.
pofs
Post by pofs » 10 Apr 2015 18:33
dolpheen wrote:Is there any info on websocket support?
Which kind of info? There are examples of using websockets in this thread.
Or do you need to connect to other websocket server from JS? This is not supported, but you can write a module for it.
