Recurring errors in OpenRemoteHelpers
Not completely sure, but I guess setVal. should be removed from line 191?
(broken since the beginning)
LOG
[2014-12-29 04:21:33.454] [E] [8083] Callback execution error: TypeError: Cannot read property 'setVal' of undefined
    at OpenRemote (automation/modules/OpenRemoteHelpers/index.js:191:73)
    at WebServerRequestHandler (automation/main.js:85:10)
CODE
190                if (mode !== null) {
191                    return zway.devices[N].ThermostatSetPoint.data[mode].setVal.value;
192                }
193                return 0;
pofs
Re: Recurring errors in OpenRemoteHelpers
Post by pofs »
No, setVal is correct (at least it is a valid name), but it seems your device doesn't have thermostat mode you're requesting. Not sure what it requires to do in this case :)
pofs wrote:Not sure what it requires to do in this case :)
I did not understand either, it was not part of my original RaZ-OR code. The only Thermostats I have are StellaZ with modes 0,1,11,31.
I did not notice problems with my devices. I was just scrutinising the logs for possible problems...
pz1 wrote:Callback execution error: TypeError: Cannot read property 'setVal' of undefined
Checked logs from today and yesterday, but did not find this error again.
Cured miraculously?
pz1 wrote:Cured miraculously?
No, I still do see this once in a while. I don't undestand what triggers this to happen. In the meantime I've asked the module developer directly.
