Backup/restore functionality not working [fixed v2.0.1-rc12]
mhorst
Post by mhorst »
The backup and/or restore functionality in the expert GUI on 2.0.1-rc7 does not seem to work for me.
For testing purposes I included one dimmer and a battery powered wall controller in my Razberry controlled network. That all works fine.
But when I use the expert GUI to make a backup and restore that backup, I end up with different devices.
After the restore I suddenly have 3 mains powered devices with incomplete interviews.
I unzipped and untarred the zbk file and checked the f9e5ea49-DevicesData.xml file. It contains three devices: the Razberry controller, the dimmer and the wall switch with ids 1, 4 and 8. This matches with the configuration I had before the restore operation. So I think the backup is working ok.
After the restore operation I have devices with ids 105, 108 and 112.
So my guess is that there is something wrong with the restore functionality.
I do see that on the controller info page the "ZMERestore (0xf3)" is shown in red, but I don't see any mention of an error or failure in the log during the restore operation.
The best way for me to get everything working again is to do a factory reset and re-include the devices, but I really liked the idea of a backup feature.
Is there any logging I can provide, or testing that I can do to help with analyzing this problem?
pofs
Re: Backup/restore functionality not working
Post by pofs »
Which RaZberry do you have? 3rd gen or 5th gen?
mhorst
Post by mhorst »
The expert UI says I have the ZW0500 Z-wave chip. From what I understand that means its 5th gen.
Could you please send us you log after recovery and your backup on info@z-wave.me. We will fix this within one-two days.
mhorst
Post by mhorst »
Ok, the information has been sent. Thanks.
mhorst
Post by mhorst »
I tried again with v2.0.1-rc10, but it still goes wrong.
mhorst
Post by mhorst »
No luck with v2.0.1-rc11 either.
Will this be fixed?
Is it a software issue, or is something wrong with my Razberry?
s/w. Will check it again.
Fixed. Will be in rc-12
mhorst
Post by mhorst »
Thanks.
I saw rc-12 was available, so I wanted to try it out. However, rc-12 failed to install:
 wget -q -O - razberry.z-wave.me/install/v2.0.1-rc12 | sudo bash
touch: missing file operand
Try `touch --help' for more information.
bash: line 16: $UPGRADING: ambiguous redirect
bash: line 17: $UPGRADING: ambiguous redirect
bash: line 58: $UPGRADING: ambiguous redirect
bash: line 59: $UPGRADING: ambiguous redirect
Removing MathKernel
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package 'wolfram-engine' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
bash: line 67: $UPGRADING: ambiguous redirect
bash: line 68: $UPGRADING: ambiguous redirect
Installing additional libraries
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Building dependency tree...
sharutils is already the newest version.
Installing additional libraries for HomeKit
libavahi-compat-libdnssd-dev is already the newest version.
bash: line 92: $UPGRADING: ambiguous redirect
bash: line 93: $UPGRADING: ambiguous redirect
Getting Z-Way for Raspberry Pi and installing
--2015-02-04 22:06:45--  http://razberry.z-wave.me/z-way-server/z-way-server/z-way-server-RaspberryPiXTools-v2.0.1-rc12.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: `/tmp/z-way-server-RaspberryPiXTools-v2.0.1-rc12.tgz'
    [ <=>        ] 10,470      --.-K/s   in 0.03s
2015-02-04 22:06:45 (322 KB/s) - `/tmp/z-way-server-RaspberryPiXTools-v2.0.1-rc12.tgz' saved [10470]
bash: line 105: $UPGRADING: ambiguous redirect
bash: line 106: $UPGRADING: ambiguous redirect
tar (child): /tmp/z-way-server/z-way-server-RaspberryPiXTools-v2.0.1-rc12.tgz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
bash: line 113: $UPGRADING: ambiguous redirect
bash: line 114: $UPGRADING: ambiguous redirect
bash: line 178: $UPGRADING: ambiguous redirect
bash: line 179: $UPGRADING: ambiguous redirect
Downloading and extracting z-way-server failed
Exiting
I think the main problem is that it tries to download the rc12 tgz file from
http://razberry.z-wave.me/z-way-server/ ... 1-rc12.tgz
instead of
Locked
