HA Schedulers don't work after upgrade to RC10
After upgrade to RC10 the HA Schedulers do not function anymore. Specifications seem OK, the controlled Scenes do function if activated from the user insterface.
Before upgrade I had made a backup of file storage/backupjson. Stopping Z-way, and restoring that backup did not solve the problem either.
I fear I have to manually define all schedules again. I had the same problem at the upgrade to RC7, but did not pay attention at that time, as I has justed started defining schedules.
Re: HA Schedulers don't work after upgrade to RC10
After a day of non functioning, I decided to open each of the existing schedules, and just push the SAVE button. To my surprise I just noticed that the first planned schedule has fired!
note: Originally I had copied the configjson file with WinSCP to my PC. For restore I did copy it to the automation directory, and moved from there to the storage directory. (could not use winscp directly with root credentials)
What am I doing wrong?
may be permission or case sensitivity in the name? (WinSCP - means Windows is involved ;)
I thought permissions were OK, but I will check again.
Edit 20140120 Permission seem to be the same as for notifications and schemas, but Owner and Group are pi instead of root
pz1 wrote:After upgrade to RC10 the HA Schedulers do not function anymore. Specifications seem OK, the controlled Scenes do function if activated from the user insterface.
I did not observe this problem with the upgrade to 2.0.1-RC11
