Error handling data from server
dolpheen
Re: Error handling data from server
Post by dolpheen » 07 Mar 2015 17:28
SolarFlor wrote:Anyway still the system is not working
"Error Handling data from server"
What do you have on http://192.168.1.22:8083/?
What is console output for 'netstat -a' command while z-way-server is running?
Razberry B+ 2.0.1-rc25 on ZW500 + 15 devices / Razberry B 2.0.1-rc25 on ZW300 for test
SolarFlor
Post by SolarFlor » 07 Mar 2015 17:39
root@raspberrypi:/opt/z-way-server# netstat -a
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 localhost:mysql         *:*                     LISTEN
tcp        0      0 *:http                  *:*                     LISTEN
tcp        0      0 *:8083                  *:*                     LISTEN
tcp        0      0 *:8084                  *:*                     LISTEN
tcp        0      0 *:ssh                   *:*                     LISTEN
tcp        0      0 *:https                 *:*                     LISTEN
tcp        0      0 raspberrypi:http        raspberrypi:36418       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36441       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36394       TIME_WAIT
tcp        0      0 raspberrypi:36535       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36452       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36431       TIME_WAIT
tcp        0      0 raspberrypi:36486       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36453       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36428       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36380       TIME_WAIT
tcp        0      0 raspberrypi:36501       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36409       TIME_WAIT
tcp        0      0 raspberrypi:36558       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36492       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36579       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36494       TIME_WAIT
tcp        0      0 raspberrypi:36519       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36478       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36438       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36421       TIME_WAIT
tcp        0      0 raspberrypi:36567       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:58768       46.20.244.72:ssh        ESTABLISHED
tcp        0      0 raspberrypi:36506       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36481       TIME_WAIT
tcp        0      0 raspberrypi:36593       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36504       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36388       TIME_WAIT
tcp        0      0 raspberrypi:36602       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36568       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36410       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36384       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36495       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36400       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36450       TIME_WAIT
tcp        0      0 raspberrypi:36488       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36408       TIME_WAIT
tcp        0      0 raspberrypi:36525       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36502       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36393       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36472       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36379       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36471       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36427       TIME_WAIT
tcp        0      0 raspberrypi:36600       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36470       TIME_WAIT
tcp        0    144 raspberrypi:ssh         utente-HP:61492         ESTABLISHED
tcp        0      0 raspberrypi:http        raspberrypi:36474       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36462       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36506       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36496       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36419       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36439       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36430       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36461       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36483       TIME_WAIT
tcp        0      0 raspberrypi:36578       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36440       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36429       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36449       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36451       TIME_WAIT
tcp        0      0 raspberrypi:36623       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36539       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36601       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36482       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36484       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36411       TIME_WAIT
tcp        0      0 raspberrypi:36547       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36612       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        android-c7a64d3e4:56502 ESTABLISHED
tcp        0      0 raspberrypi:http        raspberrypi:36473       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36485       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36407       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36397       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36401       TIME_WAIT
tcp        0      0 raspberrypi:36546       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36589       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36526       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36417       TIME_WAIT
tcp        0      0 raspberrypi:36621       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36508       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36516       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36420       TIME_WAIT
tcp        0      0 raspberrypi:36557       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36459       TIME_WAIT
tcp        0      0 raspberrypi:36548       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:36582       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36514       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36505       TIME_WAIT
tcp        0      0 raspberrypi:36515       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36517       TIME_WAIT
tcp        0      0 raspberrypi:36536       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36442       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36396       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36463       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36402       TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36493       TIME_WAIT
tcp        0      0 raspberrypi:36590       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36492       TIME_WAIT
tcp        0      0 raspberrypi:36572       192.168.1.2:950         TIME_WAIT
tcp        0      0 raspberrypi:http        raspberrypi:36460       TIME_WAIT
tcp        0      0 raspberrypi:36613       192.168.1.2:950         TIME_WAIT
udp        0      0 *:mdns                  *:*
udp        0      0 *:34835                 *:*
udp        0      0 *:bootpc                *:*
udp        0      0 localhost:37450         localhost:38738         ESTABLISHED
udp        0      0 localhost:38738         localhost:37450         ESTABLISHED
udp        0      0 raspberrypi:ntp         *:*
udp        0      0 localhost:ntp           *:*
udp        0      0 *:ntp                   *:*
udp        0      0 *:51324                 *:*
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags       Type       State         I-Node   Path
unix  2      [ ACC ]     STREAM     LISTENING     3089     /var/run/mysqld/mysqld.sock
unix  2      [ ACC ]     STREAM     LISTENING     2589     /var/run/dbus/system_bus_socket
unix  2      [ ACC ]     STREAM     LISTENING     2633     /var/run/avahi-daemon/socket
unix  9      [ ]         DGRAM                    2419     /dev/log
unix  2      [ ]         DGRAM                    3050     /var/run/thd.socket
unix  2      [ ACC ]     SEQPACKET  LISTENING     504      /run/udev/control
unix  2      [ ]         DGRAM                    2426
unix  2      [ ]         DGRAM                    2624
unix  2      [ ]         DGRAM                    3049
unix  3      [ ]         STREAM     CONNECTED     2628
unix  2      [ ]         DGRAM                    26227
unix  2      [ ]         DGRAM                    26224
unix  3      [ ]         STREAM     CONNECTED     2593
unix  3      [ ]         DGRAM                    511
unix  3      [ ]         STREAM     CONNECTED     2594
unix  3      [ ]         DGRAM                    512
unix  3      [ ]         STREAM     CONNECTED     2635
unix  3      [ ]         STREAM     CONNECTED     26140
unix  2      [ ]         DGRAM                    2700
unix  2      [ ]         DGRAM                    26137
unix  3      [ ]         STREAM     CONNECTED     2629
unix  2      [ ]         DGRAM                    2435
unix  3      [ ]         STREAM     CONNECTED     26141
unix  3      [ ]         STREAM     CONNECTED     2636     /var/run/dbus/system_bus_socket
dolpheen
Post by dolpheen » 07 Mar 2015 17:56
Looks like everything is OK.
Try to disable Cache in your Chrome. (Ctrl+Shif+J, select 'network' tab,check 'disable cache' then refresh page)
SolarFlor
Post by SolarFlor » 07 Mar 2015 18:02
this is the reply from Chrome
http://192.168.1.22:8083/ZWaveAPI/Data/0 Failed to load resource: the server responded with a status of 404 (Not Found)
factories.js:496 Error
http://192.168.1.22:8083/config/notes.log Failed to load resource: the server responded with a status of 404 (Not Found)
factories.js:419 Notes error
SolarFlor
Post by SolarFlor » 07 Mar 2015 18:06
It is like the Controller is done.
I will try to buy a new one.
How I could be sure to have a 5th generation board? any reccomanded dealer?
pz1
Post by pz1 » 07 Mar 2015 18:28
My reseller has it explicitly on offer as v2.0. They sell the old one for 50EUR, the new one for some 57EUR.
Ask your local supplier if he is not explicit in his offerings
SolarFlor
Post by SolarFlor » 07 Mar 2015 18:50
New one means ZM5202 Z-Wave transceiver module ( called 5th generation Z-Wave module)?
Please post the address of your reseller
