[solved] Raspberry pi2 razberry not including devices
Plainsane
Post by Plainsane » 20 Apr 2015 01:26
i have a raspberry pi 2 with razberry on board.
I can't get the controller to include any device.
I have excluded the device from the previous controller.
Tried the expert ui in old blue as well.
Is there a way I can sniff the tty to see if the radio is working?
Edit:
I had to have each device no more than a foot from the pi.
dolpheen
Re: Raspberry pi2 razberry not including devices
Post by dolpheen » 20 Apr 2015 13:09
Plainsane, there is no need to sniff tty to check if it works.
All transmission and configuration info you can see in '/var/log/z-way-server.log' on your razberry or attach the file here in order to analyze it.
Plainsane
Re: [solved] Raspberry pi2 razberry not including devices
Post by Plainsane » 23 Apr 2015 04:57
Thanx, but I was stupid.
