z-way-server new installation
Removing MathKernel
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package 'wolfram-engine' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Installing additional libraries
Hit
http://raspberrypi.collabora.com wheezy Release.gpg
Get:1
http://mirrordirector.raspbian.org wheezy Release.gpg [490 B]
Hit
Get:2
http://mirrordirector.raspbian.org wheezy Release [14.4 kB]
Hit
http://archive.raspberrypi.org wheezy Release.gpg
Hit
http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Get:3
http://mirrordirector.raspbian.org wheezy/main armhf Packages [6,903 kB]
Hit
Hit
http://archive.raspberrypi.org wheezy/main armhf Packages
Ign
http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign
Ign
http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign
Get:4
http://mirrordirector.raspbian.org wheezy/contrib armhf Packages [23.6 kB]
Get:5
http://mirrordirector.raspbian.org wheezy/non-free armhf Packages [49.3 kB]
Get:6
http://mirrordirector.raspbian.org wheezy/rpi armhf Packages [592 B]
Ign
http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign
Ign
http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign
Ign
http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign
Ign
http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Ign
Fetched 6,992 kB in 23s (298 kB/s)
Building dependency tree...
gawk is already the newest version.
sharutils is already the newest version.
tzdata is already the newest version.
Installing additional libraries for HomeKit
libavahi-compat-libdnssd-dev is already the newest version.
Getting Z-Way for Raspberry Pi and installing
--2015-07-26 20:44:00--
http://razberry.z-wave.me/z-way-server/ ... v2.0.1.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 12300843 (12M) [application/x-gzip]
Saving to: `/tmp/z-way-server-RaspberryPiXTools-v2.0.1.tgz'
100%[===================================================================================================================================================================================================>] 12,300,843 2.63M/s in 7.0s
2015-07-26 20:44:07 (1.68 MB/s) - `/tmp/z-way-server-RaspberryPiXTools-v2.0.1.tgz' saved [12300843/12300843]
Extracting new z-way-server
New version z-way-server installed
Creating Z-Way startup script
Adding z-way-server to autostart
update-rc.d: using dependency based boot sequencing
Getting Webif for Raspberry Pi and installing
--2015-07-26 20:44:11--
http://razberry.z-wave.me/webif_raspberry.tar.gz
Length: 401379 (392K) [application/x-gzip]
Saving to: `STDOUT'
100%[===================================================================================================================================================================================================>] 401,379 721K/s in 0.5s
2015-07-26 20:44:12 (721 KB/s) - written to stdout [401379/401379]
First install, getting razberry ID
--2015-07-26 20:44:12--
http://find.zwave.me/zbw_new_user
Resolving find.zwave.me (find.zwave.me)... 46.20.244.72
Connecting to find.zwave.me (find.zwave.me)|46.20.244.72|:80... connected.
Length: unspecified [application/octet-stream]
Saving to: `/tmp/zbw_connect_setup.run'
[ <=> ] 5,914 --.-K/s in 0s
2015-07-26 20:44:13 (45.1 MB/s) - `/tmp/zbw_connect_setup.run' saved [5914]
Now you can run zbw_connect with /etc/init.d/zbw_connect start
or simply reboot your system
Your user id: <cleaned>
Your password: <cleaned>
[....] Starting zbw_connect:[info] ok.
Getting webserver mongoose for Webif
--2015-07-26 20:44:25--
http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: `/tmp/mongoose.pkg.rPi.tgz'
100%[===================================================================================================================================================================================================>] 44,749 --.-K/s in 0.1s
2015-07-26 20:44:26 (426 KB/s) - `/tmp/mongoose.pkg.rPi.tgz' saved [44749/44749]
Stopping mongoose http server
Adding mongoose to autostart
Start mongoose http server
ls: cannot access config/zddx/*.xml: No such file or directory
Usage: ./z-cfg-update <filename>
Starting z-way-server
Starting z-way-server: done.
Thank you for using RaZberry!
