Home Automation is missing
rumcooler
Post by rumcooler »
Hello gui.
Sorry for my english
I'm new in this forum and in z-Waves ...
I need help
Last month i installed z-Way in my raspberry with raspian as os ( reading the guide online).
Probably something is wrong ...
I have only smarthome gui and expert gui but Home automation is missing... And how can i create scene?
Someone can help me?
Thank you
Rumcooler
Plainsane
Re: Home Automation is missing
Post by Plainsane »
My guess is that you have not installed 2.1.1.
Crack open that script that is on the download page and change the url.
Also noted, I had to change the script to call base name on the url as the downloaded file name is also hard coded, I'll reply here in a bit with my version.
Plainsane
Post by Plainsane »
Sorry, on my iPad, it is the best I can do
#!/bin/bash
# installer zway to raspberry
INSTALL_DIR=/opt
ZWAY_DIR=$INSTALL_DIR/z-way-server
TEMP_DIR=/tmp
BOXED=`[ -e /etc/z-way/box_type ] && echo yes`
if [[ $ZWAY_UPIF ]]; then
    write_upi() {
	echo -e $1 > $ZWAY_UPIF
else
    write_upi() {
	true;
fi
##### The percentage of updates #####
write_upi "10%\nStarting upgrading"
# Check for root priviledges
if [[ $(id -u) != 0 ]]
then
	echo "Superuser (root) priviledges are required to install Z-Way"
	echo "Please do 'sudo -s' first"
	exit 1
fi
# Accept EULA
if [[ "$BOXED" != "yes" ]]
then
	echo "Do you accept Z-Wave.Me licence agreement?"
	echo "Please read it on Z-Wave.Me web site: http://razberry.z-wave.me/docs/ZWAYEULA.pdf"
	while true
	do
		echo -n "yes/no: "
		read ANSWER < /dev/tty
		case $ANSWER in
			yes)
				break
			no)
				exit 1
		esac
		echo "Please answer yes or no"
	done
fi
# Check if Z-Way was already installed in /opt/z-way-server
upgrade_zway="no"
if [[ -d $ZWAY_DIR ]]; then
	upgrade_zway="yes"
else
	echo "z-way-server new installation"
fi
write_upi "20%\nRemoving MathKernel"
echo "Removing MathKernel"
# In raspbian 2014-01-07 in init.d script error, it does not allow add new scripts to the startup
apt-get -y remove wolfram-engine
write_upi "30%\nInstalling additional libraries"
echo "Installing additional libraries"
apt-get -y update
apt-get -qy install sharutils tzdata gawk
echo "Installing additional libraries for HomeKit"
apt-get -qy install libavahi-compat-libdnssd-dev
if [[ ! -e /usr/lib/arm-linux-gnueabihf/libssl.so ]]
	then
	echo "Making symlinks to libssl.so"
	cd /usr/lib/arm-linux-gnueabihf/
	ln -s libssl.so.1.0.0 libssl.so
fi
if [[ ! -e /usr/lib/arm-linux-gnueabihf/libcrypto.so ]]
	then
	echo "Making symlinks to libcrypto.so"
	ln -s libcrypto.so.1.0.0 libcrypto.so
fi
write_upi "40%\nGetting Z-Way for Raspberry Pi"
URL='http://razberry.z-wave.me/z-way-server/z-way-server-RaspberryPiXTools-v2.1.2-rc2.tgz'
FILE=`basename $URL`
if [[ -e $TEMP_DIR/$FILE ]]; then
	echo "Removing duplicate of z-way installer"
	rm -rf $TEMP_DIR/$FILE
fi
echo "Getting Z-Way for Raspberry Pi and installing"
wget -4 $URL -P $TEMP_DIR/
write_upi "50%\nExtracting new z-way-server"
# remove z-way-server if exist
rm -rf $TEMP_DIR/z-way-server
# Extracting z-way-server
echo "Extracting new z-way-server"
tar -zxf $TEMP_DIR/$FILE -C $TEMP_DIR
write_upi "60%\nMaking backup and installing Z-Way"
# If downloading and extracting is ok, then make backup and move z-way-server from /tmp to /data
if [[ "$?" -eq "0" ]]; then
	# if need upgrade
	if [[ "$upgrade_zway" = "yes" ]]; then
		echo "Previous z-way-server installation found"
		# Stopping z-way-server
		if [[ -e /etc/init.d/z-way-server ]]
		then
			/etc/init.d/z-way-server stop
		fi
		if [[ -e /etc/init.d/Z-Way ]]
		then
			/etc/init.d/Z-Way stop
			rm /etc/init.d/Z-Way
		fi
		# Make backup
		TMP_ZWAY_DIR=${ZWAY_DIR}_$(date "+%Y-%m-%d-%H-%M-%S")
		echo "Making backup of previous version of Z-Way in $TMP_ZWAY_DIR"
		mv $ZWAY_DIR $TMP_ZWAY_DIR
		mv $TEMP_DIR/z-way-server $INSTALL_DIR/
		# Copy old configuration files to the new location
		echo "Copying settings"
		cp $TMP_ZWAY_DIR/config/Configuration.xml $ZWAY_DIR/config/
		cp $TMP_ZWAY_DIR/config/Rules.xml $ZWAY_DIR/config/
		cp -R $TMP_ZWAY_DIR/config/maps $ZWAY_DIR/config/
		cp -R $TMP_ZWAY_DIR/config/zddx $ZWAY_DIR/config/
		if [[ -e $TMP_ZWAY_DIR/automation/.syscommand ]]
			then
			cp $TMP_ZWAY_DIR/automation/.syscommand $ZWAY_DIR/automation/.syscommand
		fi
		if [[ -d $TMP_ZWAY_DIR/automation/storage ]]
			then
			rm -Rf $ZWAY_DIR/automation/storage
			cp -R $TMP_ZWAY_DIR/automation/storage $ZWAY_DIR/automation/
		fi
		if [[ -d $TMP_ZWAY_DIR/automation/userModules ]]
			then
			rm -Rf $ZWAY_DIR/automation/userModules
			cp -R $TMP_ZWAY_DIR/automation/userModules $ZWAY_DIR/automation/
		fi
		if ! diff $ZWAY_DIR/config.xml $TMP_ZWAY_DIR/config.xml -w > /dev/null
		then
			echo "config.xml replaced by the new one - make sure to restore your changes"
			echo "diff $ZWAY_DIR/config.xml $TMP_ZWAY_DIR/config.xml:"
			echo
		fi
		echo "!!! Defaults.xml and config.xml updated with new versions !!!"
	else
		echo "New version z-way-server installed"
	fi
else
	write_upi "30%\nDownloading and extracting z-way-server failed"
	echo "Downloading and extracting z-way-server failed"
	echo "Exiting"
	exit 1
fi
mkdir -p /etc/z-way
echo "v2.0.1" > /etc/z-way/VERSION
echo "razberry" > /etc/z-way/box_type
# Create Z-Way startup script
echo "Creating Z-Way startup script"
echo '#! /bin/sh
### BEGIN INIT INFO
# Provides:		  z-way-server
# Required-Start:
# Required-Stop:
# Default-Start:	 2 3 4 5
# Default-Stop:	  0 1 6
# Short-Description: RaZberry Z-Wave service
# Description:	   Start Z-Way server for to allow Raspberry Pi talk with Z-Wave devices using RaZberry
### END INIT INFO
# Description: RaZberry Z-Way server
# Author: Yurkin Vitaliy <aivs@z-wave.me>
PATH=/bin:/usr/bin:/sbin:/usr/sbin
NAME=z-way-server
DAEMON_PATH=/opt/z-way-server
PIDFILE=/var/run/$NAME.pid
# adding z-way libs to library path
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/z-way-server/libs
case "$1" in
  start)
	echo -n "Starting z-way-server: "
	start-stop-daemon --start  --pidfile $PIDFILE --make-pidfile  --background --no-close --chdir $DAEMON_PATH --exec $NAME > /dev/null 2>&1
	echo "done."
  stop)
	echo -n "Stopping z-way-server: "
	start-stop-daemon --stop --quiet --pidfile $PIDFILE
	rm $PIDFILE
	echo "done."
  restart)
	echo "Restarting z-way-server: "
	sh $0 stop
	sleep 10
	sh $0 start
  save)
	echo "Saving z-way-server configuration"
	PID=`sed s/[^0-9]//g $PIDFILE`
	/bin/kill -10 $PID
	echo "Usage: /etc/init.d/z-way-server {start|stop|restart|save}"
	exit 1
esac
exit 0' > /etc/init.d/z-way-server
chmod +x /etc/init.d/z-way-server
# Add z-way-server.log to logrotate
echo '/var/log/z-way-server.log {
        daily
        size=10M
        rotate 4
        compress
        nodelaycompress
        missingok
        notifempty
        postrotate
    		/usr/bin/killall -HUP z-way-server 2>/dev/null || true
		endscript
}' > /etc/logrotate.d/z-way-server
# Add Z-Way to autostart
echo "Adding z-way-server to autostart"
update-rc.d z-way-server defaults
write_upi "70%\nGetting Webif for Raspberry Pi and installing"
# Getting Webif and installing
echo "Getting Webif for Raspberry Pi and installing"
wget -4 http://razberry.z-wave.me/webif_raspberry.tar.gz -O - | tar -zx -C /
# If first install, get new ID
if [[ ! -e /etc/init.d/zbw_connect ]]
	then
	echo "First install, getting razberry ID"
	echo '#!/bin/bash
### BEGIN INIT INFO
# Provides:          zbw_autosetup
# Required-Start:    $all
# Required-Stop:     $all
# Short-Description: zbw_autosetup
# Description:       the script setup a zbw_connect script
### END INIT INFO
function delete_me()
    insserv -r zbw_autosetup
    rm -f /etc/init.d/zbw_autosetup
    rm -f $0
if [[ $0 == "/tmp/zbw_autosetup" ]]; then
    delete_me;
    exit
fi
case "$1" in
    start)
        # if we already have zbw_connect, delete ourself
	if [[ -x /etc/init.d/zbw_connect ]]; then
	    # a hack to eliminate an error on a remouting / ro
	    cp $0 /tmp/zbw_autosetup
	    exec /tmp/zbw_autosetup
	fi
        if wget -4 http://find.zwave.me/zbw_new_user -O /tmp/zbw_connect_setup.run; then
            sleep 10
	    if bash /tmp/zbw_connect_setup.run; then
	        /etc/init.d/zbw_connect start
	    fi
	    mount -o remount,ro /
	fi
esac
' > /etc/init.d/zbw_autosetup
	chmod +x /etc/init.d/zbw_autosetup
	/etc/init.d/zbw_autosetup start
else
	# Update zbw_connect to new version
	cd /etc/init.d/
	./zbw_connect stop
	echo 'begin-base64 644 zbw_connect_with_out_key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====' | uudecode  -o zbw_connect.new
	tail -n 29 zbw_connect >> zbw_connect.new
	mv zbw_connect.new zbw_connect
	chmod +x zbw_connect
	echo "zbw_connect patched"
	./zbw_connect start
fi
write_upi "80%\nGetting webserver mongoose for Webif"
# Getting webserver mongoose for webif
cd $TEMP_DIR
if [[ -e mongoose.pkg.rPi.tgz ]]; then
	echo "Removing duplicate of mongoose"
	rm -rf mongoose.pkg.rPi.tgz
fi
echo "Getting webserver mongoose for Webif"
wget -4 http://razberry.z-wave.me/mongoose.pkg.rPi.tgz -P $TEMP_DIR
write_upi "90%\nRestarting Webif and Z-Way"
# Stopping mongoose
if [[ -e /etc/init.d/mongoose ]]
then
	echo "Stopping mongoose http server"
	/etc/init.d/mongoose stop
fi
# Installing webserver mongoose for webif
tar -zxf $TEMP_DIR/mongoose.pkg.rPi.tgz -C /
# Adding webserver to autostart
echo "Adding mongoose to autostart"
update-rc.d mongoose defaults
# Starting webserver mongoose
echo "Start mongoose http server"
/etc/init.d/mongoose start
# Prepare AMA0
sed 's/console=ttyAMA0,115200//; s/kgdboc=ttyAMA0,115200//' /boot/cmdline.txt > /tmp/zway_install_cmdline.txt
sed 's|[^:]*:[^:]*:respawn:/sbin/getty[^:]*ttyAMA0[^:]*||' /etc/inittab > /tmp/zway_install_inittab
# Transform old DevicesData.xml to new format
(cd $ZWAY_DIR && test -x ./z-cfg-update && ls -1 config/zddx/*.xml | LD_LIBRARY_PATH=./libs xargs -l ./z-cfg-update)
if diff /boot/cmdline.txt /tmp/zway_install_cmdline.txt > /dev/null || diff /etc/inittab /tmp/zway_install_inittab > /dev/null
then
	rm /tmp/zway_install_cmdline.txt /tmp/zway_install_inittab
	# Starting z-way-server mongoose
	echo "Starting z-way-server"
	/etc/init.d/z-way-server start
else
	echo "Preparing AMA0 interface:"
	echo " removing 'console=ttyAMA0,115200' and 'kgdboc=ttyAMA0,115200' from kernel command line (/boot/cmdline.txt)"
	mv /tmp/zway_install_cmdline.txt /boot/cmdline.txt
	echo " removing '*:*:respawn:/sbin/getty ttyAMA0' from /etc/inittab"
	mv /tmp/zway_install_inittab /etc/inittab
	echo "AMA0 interface reconfigured, please restart Raspberry"
fi
# Make sure to save changes
sync
# Subscribe user to news
then
	echo "Do you want to receive emails with news about RaZberry project?"
	echo "! Please subscribe again if you did it before 30.03.2013"
	while true
	do
		echo -n "yes/no: "
		case $ANSWER in
			yes)
				echo -n "Enter your email address: "
				read EMAIL < /dev/tty
				curl -d "email=$EMAIL" http://razberry.z-wave.me/subscribe.php
				break
			no)
				break
		esac
	done
fi
echo "Thank you for using RaZberry!"
exit 0
rumcooler
Post by rumcooler »
Thank you for your fast reply.
On next week end i will try your script.
I have to create e blank file with your code, setting the correct permisson and run from root?
Thank you
Rumcooler
Plainsane
Post by Plainsane »
Yes, paste into a file.
cat <file> | sudo bash
REMEMBER change the URL in the file. Currently it pulls 2.1.2rc2 which is no good for keeping switch state
