compatible with raspberry pi model a?
I have an original model A laying around and was wondering if the RaZberry was compatible.
Re: compatible with raspberry pi model a?
Yes, I have the latest release candidate 2.1.2-rc17 running on it with the first Generation RaZberry. I quess it will work with UZB1 and 5gen RaZberry. It is substantially slower than Raspi 2, but perfect as a starter
Thanks for the help, I ended up purchasing one (5th gen) and it seems to work with my Raspberry Pi Model A. The only thing was it was a little tricky juggling the single USB port (and no Ethernet port). Also I'm having problems connecting to :8084 (the same issue as viewtopic.php?f=3422&t=22096), but I'm able to connect to :8083 fine.
