one time condition
Posted: 02 Feb 2016 17:40
I need to make Rule that will be turning ON a binary switch when the light sensor sends some value to the controller.
sensor sends update of for example luminescence only when the light condition is changing.. and only then I want to turn on the binary switch.
Later if I manually set the binary switch OFF - I don't want a situation when it will be turn On back
only next time when sensor sends the same value to the controller (it will be next day)..
