Problems with some thermostats
yoch
Post by yoch » 10 Feb 2016 20:43
I use Danfoss thermostats (living-connect 1.1) for heating regulation with z-way 2.01. Suddenly, some of them no longer work (they ignore ThermostatSetPoint commands).
I have no idea about the problem, but I foud many curious lines in the queue like to :
1				E	D	-	+	+	4.65	65	Clock Report	Delivered	41 4 81 6 d5 29 5
1				E	D	-	+	+	4.65	65	Schedule Change Report (schedule change mechanism disabled)	Delivered	41 3 46 5 0 5
0					D	-	-	-	4.60	65	Wakeup Sleep
And in logs :
[2016-02-06 23:19:31.832] [D] [zway] SETDATA devices.37.instances.0.commandClasses.70.data.overrideType = 0 (0x00000000)
[2016-02-06 23:19:31.832] [D] [zway] SETDATA devices.37.instances.0.commandClasses.70.data.overrideState = 127 (0x0000007f)
Also, I saw that some users have had problems with this device : https://forum.z-wave.me/viewtopic.php?f=3424&t=20111
Any idea to solve this problem ? Does the solution proposed in the cited topic is still relevant ?
Best regards
cbnidk
Re: Problems with some thermostats
Post by cbnidk » 14 Feb 2016 14:59
Hi
I have this ver.
Living Connect 013
Application version 1.1
SDK version 4.55.00
and I use firmware version v2.2.1-rc6 of z-wave server on a raspberry pi and I have no problem, all is working
are the living connect gets awake like you set it to?
I have every 5 min.
cbni
xwolverinex
Post by xwolverinex » 21 Feb 2016 01:22
Does someone knows the different between Living Connect 013 and living-connect 1.1?
Post by pz1 » 21 Feb 2016 11:56
Living Connect 013 is latest release. Earlier versions have given considerable trouble. Don't know if there is significant use of this newer version
