Firmware upgrade fails
bilakos
Post by bilakos »
Hi All,
This is the first time I am using this piece of SW/HW and I was experementing with inclusion of Aeotec's Smart Switch 6. I did all as described in several HOWTOs, but was not successful including this.
So I entered the the Expert UI to find out which frequency my razberry is using and saw: unknown. Tried to switch it to EU, but also without success. So I decided to lookout for a firmware upgrade as I bought the razberry board already 6 months ago (Current FW: 5.0).
There I received an error message "Error handling data".
Anyone who can help with this ? Is there a script I could run to upgrade my controller ?
bilakos
Re: Firmware upgrade fails
Post by bilakos »
I just looked up also the log and it says
"[2016-02-26 05:33:38.310] [core] Failed to download firmware: Not Found"
bilakos
Post by bilakos »
Finally, I found out that I received a wrong Razberry board. Seems like they sent me a US frequency board :(.
Truly a pitty. Now I have a US board, which I can't use here....
nochkin
Post by nochkin »
bilakos wrote:There I received an error message "Error handling data".
It seems like the website hosting the binary files is not working properly.
I tried to debug the code and it appears it tries to fetch this for me:
http://www.zwave.eu/api/expertui/uzb/bo ... A9.hex.bin
But the file returns Error 404 (not found).
If the issue is on a remote side, the admins should do something. There is nothing you can do on your side unless you have a way to contact admins directly and ask.
bilakos
Post by bilakos »
Yep, indeed.
Anyone working on this. Would be great if this works...
herbert-f
Post by herbert-f »
Good Morning,
in this thread https://forum.z-wave.me/viewtopic.php?f ... 1&start=10 it's the same problem. How can I contact the admins ?
Bye herbert
pz1
Post by pz1 »
herbert-f wrote:How can I contact the admins ?
info@z-wave.me
Thanks, we are aware of the issue, will fix it soon
bilakos
Post by bilakos »
Andy Update in this issue?
Plainsane
Post by Plainsane »
bilakos wrote:Andy Update in this issue?
--redacted--
they either don't care or don't know....not sure which one now at this point.
Openhab2 is shaping up and I'm moving in that direction.
