So I have a couple of Danfoss Living Connect radiator thermostats installed and connected through Z-Wave. The instructions from Danfoss state that if I manually adjust the temperature on the thermostat then the Z-wave controller should adjust all the other thermostats in the same room as well. This doesn't seem to be the case for me and I have to set the temperature on all the thermostats even though they are assigned to the same room in the Z-wave web GUI.
What am I missing here?
Thanks a bunch
Room-based temperature adjustment
Re: Room-based temperature adjustment
I think this is only true if you use Danfoss' own controller.homespear wrote:The instructions from Danfoss state that if I manually adjust the temperature on the thermostat then the Z-wave controller should adjust all the other thermostats in the same room as well.
