Hello together,
i have an issue with a local user. I deleted the local host user, cause i don't get in touch from command line with api without login. Then i wanted to create a new local host user... yes i do but only with login. If i want to set this user without passwort the form will denied any further assist... How can i create now a local user without login?
I using v2.2.2-rc3.
PS: The Api denied access with error 401 authorisation required from command line.
Thanks.
New localhost user needs password
Greatings from the noob
Re: New localhost user needs password
local user will work only if you access from the same host, means from 127.0.0.1 to 127.0.0.1
To use API you still need to get session cookie.
