I'm using version 2.2.3 and having serious problems with my qubino relays.
I have three relays which is not working well.
1. First of all the inclusion process never gets to 100%. If continued anyway sometimes it looks ok.
2. The interview is never complete. It is missing version.
3. All configuration for theses three relays is lost when z-way-server is restarted and I have to force an interview again (I have a sensor that is working ok)
Does anyone else have these problems or even better, have a solution for it?
Regards Mats
Configuration is lost after restart
Re: Configuration is lost after restart
I have similar problem with v2.2.4-rc4 but on all devices.
Any way to get my QUBINO devices working, I simply make a "call nif" and "force interview" (I'm not so happy to do this every time) till it is complete. Once interview is complete, I go throught expert command and in the configuration section I get all the parameter I need one by one. Everythyng work fine even if for my QUBINO there isn't a relevant file description.
Marco
Basically when you do /etc/init.d/z-way-server stop ot use /JS/Run/exit() API call, Z-Way should save current state before shut down. If it does not work for you, we will need remote support to investigate
None of the suggested is working. How would a remote support look like?
There is a check box for this in maintainance and you need to send us ID and password
Nope, unfortunately not!. I have sent a PM to PoltoS but I have gotten no response.
@Mansica Indeed, missed it. too many entrence points: e-mail, skype, PM, facebook,.... lost between all of them.
So, can you reproduce the problem so we can help to debug it?
It is very easy to reproduce it. Just restart z-way-server and all configuration is lost.
Please provide access and show us. We will fix this asap
