Hello
Within LAN, I am able to login and no disconnection from the server.
However, remotely, I get intermittent error messages as attached.
It works for the first couple of seconds where I can navigate the pages as per normal and then the error comes up.
Any ideas?
Cheers
Connection refused by the z-way-server
- zway.PNG (15.85 KiB) Viewed 11719 times
Re: Connection refused by the z-way-server
I have the exact same problem. I rebooted my raspberry but that didn't help. Did you get it solved, if so how did you do it?
Hey,
I've got the same error message since a few days. Lan and remote access. How did you solve this problem?
In my opinion the connection is fine, so I think the real problem is another one.
Best greetings
dti
Best greetings
dti
Problem solved.
I've deleted the notification file, cause it has been to big. After that the system runs very fast again
I just got the same message when I was trying to setup RaZberry on the new Raspbian Stretch. @dti, where is the notification file?
OK, I know what's going on. It's because I use the latest Raspbian Stretch, it's too new which is somehow incompatible with z-way-server. So, please use Jessie instead.jacksun101 wrote: ↑30 Aug 2017 12:59I just got the same message when I was trying to setup RaZberry on the new Raspbian Stretch. @dti, where is the notification file?
I'm experiencing the same now with 2.3.8. Highly unstable.
I have performed format and fresh install from image, followed by firmware update, twice:
http://razberry.z-wave.me/z-way-server/razberry.img.zip
Where to start debugging?
downgrade to 2.3.7 and it seems to run without issues.
