- 403.JPG (45.59 KiB) Viewed 14329 times
Surveillance cam
Re: Surveillance cam
If I put username and password in the corresponding fields, and not in the URL, it seems that I get another error.
This is what it should look like.
have also shown the xml code for the element, if this could make any sense for you that understand this stuff.
Aha...I have now found the solution I think.
I need to use the username and password field in the app. Username and password can`t be integrated in the URL.
The reason I couldn`t login and got the 403, seem to be because the camera only supports one login or connection.
I now got picture from both my cameras.
I still can`t get picture with the Zway control app, (Apple app store), but maybe this isn`t supported?
Maybe it is supported if I set the cameras up with the dyndns function to get direct access outside the firewall?
Wowww...but it obviously works in the Home Control app...
I got the video stream working in the iphone app and in the ipad app - with different cameras.
Works with an standard ip cam, also with a webcam stream that i found which was open without password and as well with an iphone and an android phone with installed webcam app.
All works great, but i had to fiddle around which "camera" to chose - not all worked straight with standard webcam module, for some i found dedicated webcam modules (for special brand of webcams) that worked. I think this depends on the type of stream. I didn't write down which stream type works with which webcam module, as I was only trying it out anyways.
By the way:
For cheap surveillance i may recommend an old android phone with good camera and the app "IP Webcam".
This app is quite all you might want (even in the free version) and works stable and well with zway.
In its free version it supports automatic streaming after phone boot, hiding the app on the phone, rotating and mirroring the picture, using front or rear cam, switching on the light remotely, adjusting brightness and contrast as well as night mode, it allows to define overlay text in unix format like %A%d%m%y%s to add time, a clear dayname and date to the stream and as well allows to automatically upload pictures or video streams of definable leghth to FTP oder even dropbox upon motion detection, and also allow to trigger http requests upon motion triggerering.
By the way:
In URL:
http://your_ip/streaming/channels/2/preview
In user:
user_name_camera_login
In password:
user_password_camera_login
Camera ip and z-way-server ip must be in same LAN.
In user:
In password:
- Contact:
As PolTos said, Your MJPEG is supported, I think there is the problem in the configuration of your camera app in Z-way. I have no more information about "'HikVision IP-camera'', for more, you can search online definitely your all doubts will be clear.
