Server is constantly crashing
jet11x
Re: Server is constantly crashing
Post by jet11x » 23 Jan 2018 23:46
And died again - I've disable my HTTPDevice plugin as that's almost certainly causing the crashes.
Shame about that - if you can fix this that's great, otherwise I'll have to consider checking alarm status in another process and then changing a device in z-wave.me process. Won't have time for the re-code in the foreseeable future though.
Post by PoltoS » 24 Jan 2018 00:13
Can ypu provide me an example of the request, reply and HTTPDevice configuration - we can make 1000 requests per second to see if the error happens
añep
Post by añep » 02 Feb 2018 17:44
Without HTTPDevice configuration, it continue crashing. I have fresh installs and the same problem. Always v2.3.6 and firmware updated.
Hardware
Vendor: RaZberry by Z-Wave.Me
Vendors Product ID: 1024 / 2
Z-Wave Chip: ZW0500
Firmware
SDK Version: 6.71.01
Serial API Version: 05.23
Regards.
jet11x
Post by jet11x » 06 Feb 2018 23:42
@PoltoS - my apologies for taking so long to response to you request for examples.
I've put together all the details I think you'll need in the attached.
Of course I don't know if a different format of response is what's causing the crash - let me know if you have a debug version with extra logging that you'd like me to try.
Regards
visonic-usage.tar.gz
(3.38 KiB) Downloaded 131 times
jet11x
Post by jet11x » 26 Feb 2018 14:37
Any update on this issue?
Post by PoltoS » 27 Feb 2018 13:57
We are trying to locate the bug. We see some reports about openHAB integration (also HTTP) to cause random crash. The problem is a memory override in some place, so pretty hard to find. And we can not reproduce it in our lab - this makes us mad, because this might mean dependance on some arch or what ever else.
The more debug info (mostly gdb reports) we find, the better we can understand what happens
jet11x
Post by jet11x » 29 Mar 2018 16:30
Got a crash without my HTTPDevice plugin activated.
Now installed monit to auto restart z-wave-server if it crashes.
Post by PoltoS » 02 Apr 2018 10:15
Can you give us the gdb report?
jet11x
Post by jet11x » 02 Apr 2018 10:57
I don't have it running under gdb all the time. Is there a way I can do that and still run it as a background process?
Post by PoltoS » 16 Apr 2018 01:44
Yes, use "screen".
Is the problem still relevant on v2.3.7? If so, can you help us to reproduce it or use your environment to hunt?
