Pi model 3B + Stretch + RaZberry2
lordchilli
Post by lordchilli » 30 Jun 2018 01:17
Hi everyone,
i also had problems with RaZberry2 and the Pi model 3b (stretch)
According to the sticky I installed:
wget -q -O - support.zwave.eu/libs | sudo bash
and
I'm afraid it didn't work. From the log:
2018-06-13 18:01:55.198] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2018-06-13 18:01:55.399] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2018-06-13 18:01:55.399] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2018-06-13 18:01:55.399] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
After googling a lot i found this:
  • Disable Bluetooth manually on RPI3B
    Open the /boot/config.txt
    sudo nano /boot/config.txt
    At the end add the line:
    dtoverlay=pi3-disable-bt
    Save file: exit with ctrl-O, select Yes
  • We also need to run to stop BT modem trying to use UART
    sudo systemctl disable hciuart
    After this: REBOOT
  • set the correct baudrate
    stty -F /dev/ttyAMA0 9600
Now it works for me :-)
Credits: https://openenergymonitor.org/forum-arc ... 12311.html and https://www.raspberrypi.org/forums/view ... p?t=139927
DJay
Re: Pi model 3B + Stretch + RaZberry2
Post by DJay » 30 Jun 2018 13:18
Thanks you so much. This worked for me as well.
Appreciate your step by step instruction so a beginner like me could easily handle it.
Z-wave.me Razberry is now working as it should be on my Pi 3 B+ stretch.
Many thanks!
Patrick
Post by Patrick » 16 Jul 2018 22:14
i have a Pi Modell 2B + Strech + RaZberry2 and i did exactly the same and i have exactly the same behavier.
but the solution above does not work, i think becuase i habe a Modell 2B.
I have tried with baudrate 9600 and 115200..
Thank you very much in advance
Nolv
Post by Nolv » 13 Aug 2018 21:11
I have a Pi Modell 3B + Stretch + RaZberry2
I did exactly the same and i have exactly the same behavier.
but the solution above does not work.
I get the message ERR_CONNECTION_REFUSED from my Web browser.
Any other suggestions?
Many Thanks!
pimmen
Post by pimmen » 16 Sep 2018 16:39
i have the same issues, get frequent "unable to load data" messages.
Greek
Post by Greek » 20 Sep 2018 07:13
i have the same issues, get frequent "unable to load data" messages. model 3B+
Post by PoltoS » 20 Sep 2018 09:32
Please provide us remove access to let check this
jr142
Post by jr142 » 18 Oct 2018 12:36
I have the same Problem, I changed everything but I have no connection.
According to DJays german manual, he used zwave version 2.3.7 and the latest download from zwave.me is 2.3.8
This is the only difference i can imagine.
jr142
Post by jr142 » 18 Oct 2018 15:24
I tried all changes with version v2.3.7 but it isn't working either.
I could imagine that there are some serial port settings to change, could anyone of you discribe your settings?
Or what system are you using?
I'm actually using Raspbian NOOBS V2.8.2
