Can't set frquency to AU/NZ
aus_fas
Post by aus_fas » 16 Oct 2018 04:18
I bought Razberry V2 card from the local seller in Australia and he is insisting that all the boards are for AU frequencies. However, if I go into expert mode I only see EU/IN/RU/CH and no option to set AU/NZ frequency. I have tried the steps in https://forum.z-wave.me/viewtopic.php?f=3422&t=25882
but still the same issue.
Also why am I having the following ZEMRestore in red in the Controller Info page in expert mode
I have updated it to the latest firmware as well.
Any idea how to set the frequency.
Re: Can't set frquency to AU/NZ
Post by PoltoS » 17 Oct 2018 09:21
Do right in the URL /JS/Run/zway.ZMEFreqChange(4)
aus_fas
Post by aus_fas » 18 Oct 2018 07:10
Thanks, it worked!
DavidL
Post by DavidL » 06 Nov 2018 07:19
Where is the US in the button choices? Firmware says US, but no US selection.
I tried
http://myIP:8083/JS/Run/zway.ZMEFreqChange(9)
and then saw US. I clicked on US and it changed to US.
I now can add devices...
asiobob
Post by asiobob » 08 Dec 2018 09:08
@PoltoS it would be great if the UI can show the ANZ frequency / any other compatible frequencies.
When I first bought the Razberry I spent an entire weekend trying to work the lack of ANZ out; the vendor even posted me a new board in case there was an issue. It took a long time to find thie URL method to setting the freq
silverhack
Post by silverhack » 21 Dec 2018 08:52
I also had this same problem after upgrading firmware. I used /JS/Run/zway.ZMEFreqChange(9) and then I could see US in the list and changed to US frequency. Thanks @DavidL for the info, this got me working again!
DavidL
Post by DavidL » 17 Apr 2019 19:23
I just got burned yet again with this issue, forgetting that I had the problem 6 months ago....
Using latest firmware / software and again couldn't set US market.
I haven't been able to try the "fix" listed in this thread again.
Will post back if it doesn't work..
Can this be fixed in the firmware next release?
DavidL
Post by DavidL » 17 Apr 2019 21:50
I was able to use the URL "fix" and was then able to select US.
So this is a small bug that needs to be addressed so it doesn't keep coming up.
Wasted about 6 hours on this just today.
Post by PoltoS » 19 Apr 2019 22:16
Sorry, this was fixed in dev version. Will be in the next release
