"dead" device in app but not webUI
Posted: 08 Nov 2018 09:24
by patric.f
I just bought a bunch of Fibaro Dimmer 2 and a Razberry to go with it.
I've installed Z-Way on my Rasberry Pi 3 and at first I had problems including one dimmer but later got it working.
Somehow there was a problem that made the dimmer stop working and I had to exclude it and do it all over.
However, now I have a "dead" device in my app on my phone but not in the webUI and I can't get rid of it.
If I click on it I get the menu to dim etc. but it doesn't work. And not just that, when I'm using the app to turn on/dim the dimmer that is working it will just blink really quick and then shut off and the Z-Way server will crash on the RaspberryPi. If I try to turn it on using the physical switch it does the same. So now I can't turn on the lights in the kitchen. I have to start the Z-Way server again and do a factory reset to the dimmer and include it again for it to work. But as soon as I start using the app again it will fail all over again.
Is there a way to fix this or should I just start all over with a new installation on the RaspberryPi?
Re: "dead" device in app but not webUI
Posted: 09 Nov 2018 01:22
by patric.f
It seems to have removed itself because it's gone now..
