Close Z-Way reactivate Bluetooth
Marius96
Post by Marius96 » 14 Mar 2019 09:49
how can i deactivate the z-way server and reactivate the bluetooth adapter on my raspberry pi 3?
Wrote the following script to start:
#!/bin/bash
echo "Should the Z-Wave-Server be started?"
echo -n "[yes/no] "
read ANSWER
if [ "$ANSWER" == "yes" ]
        then
                echo "The server will be started..."
                COMMAND="sudo /etc/init.d/z-way-server start"
                $COMMAND
                chromium-browser http://localhost:8083/
		read -n 1 -s -r -p "Press any key to close terminal"
fi
an to stop the z-way server:
#!/bin/bash
echo "Should the Z-Wave-Server be stopped?"
echo -n "[yes/no] "
read ANSWER
	then
		echo "The server will be stopped..."
		COMMAND="sudo /etc/init.d/z-way-server stop"
		$COMMAND
fi
But when i stopped the z-way server the bluetooth adapter says 'No Bluetooth adapter found', how is it possible to activate the bluetooth adapter via script or something?
Re: Close Z-Way reactivate Bluetooth
Post by PoltoS » 14 Mar 2019 20:53
Please check the install script. It is changing the serial port settings in the Pi
Marius96
Post by Marius96 » 16 Mar 2019 17:13
PoltoS wrote:
14 Mar 2019 20:53
Hello PoltoS thanks for your answer.
I've checked the install script and expand my program by the following command to reactivate the bluetooth adapter:
sudo systemctl enable hciuart    # Because the install script includes "sudo systemctl disable hciuart"
and i removed the line "pi3-disable-bt" from the /boot/config.txt. Is there any other changes at the seriel port settings necessary?
After reboot of my raspberry pi the bluetooth adapter seems to be active but i get some errors when i connect to other bluetooth devices.
Post by PoltoS » 06 Apr 2019 17:37
Should be enough
