Fibaro FGBS-001Universal sensor Not in device list
Spirit78
Post by Spirit78 » 14 Apr 2019 22:04
I have some troubles with my Fibaro FGBS-001. It doesn´t respond correctly since the the update to 2.3.8-rc4
I use the two inputs to get statuses from the two inputes, and have also two Dallas temperature sensors ( they work just fine )
The problem is that it dosen´t always update its status, so an input can show its triggered even though its not and so on.
Now I noticed that its not present in the device list in expert UI, Can that have anything to do with it at all?
I had an older version of the sensor but replaced it with a brand new one (v 2.1) and it is still the same problem. And I have updated the device list in Firmware UI
Re: Fibaro FGBS-001Universal sensor Not in device list
Post by PoltoS » 15 Apr 2019 02:46
Can you check the log - do you see incoming packets from RF level once status change? If yes, the problem is in the FGBS. If not, we need to get more info (including the log) to explain it.
Spirit78
Post by Spirit78 » 15 Apr 2019 22:41
Can I mail you the log? And give you som explanations to it?
Spirit78
Post by Spirit78 » 16 Apr 2019 21:31
Polto S, is this of any help?
It´s the device 5 and input 1 and 2 that is of interest.
[2019-04-16 20:25:25.095] [D] [zway] SETDATA devices.10.instances.0.commandClasses.38.data.level = 75 (0x0000004b)
[2019-04-16 20:25:25.125] [D] [zway] RECEIVED: ( 01 0F 00 04 00 05 07 60 0D 01 01 20 01 00 C9 00 73 )
[2019-04-16 20:25:25.125] [D] [zway] SENT ACK
[2019-04-16 20:25:25.125] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2019-04-16 20:25:25.125] [D] [zway] SETDATA devices.1.instances.1.commandClasses.32.data.srcNodeId = 5 (0x00000005)
[2019-04-16 20:25:25.125] [D] [zway] SETDATA devices.1.instances.1.commandClasses.32.data.srcInstanceId = 1 (0x00000001)
[2019-04-16 20:25:25.125] [D] [zway] SETDATA devices.1.instances.1.commandClasses.32.data.level = 0 (0x00000000)
[2019-04-16 20:25:25.125] [D] [zway] SETDATA devices.5.instances.1.commandClasses.48.data.1.level = False
[2019-04-16 20:25:25.125] [D] [zway] SETDATA devices.5.instances.1.commandClasses.48.data.1 = Empty
[2019-04-16 20:25:25.148] [core] Notification: device-info (device-OnOff): {"dev":"Fibaro (5.1.1) Button"
[2019-04-16 20:25:25.176] [core] Notification: device-info (device-OnOff): {"dev":"Köksfläkt Läge 2 (5.1)"
[2019-04-16 20:25:25.227] [D] [zway] RECEIVED: ( 01 0F 00 04 00 05 07 60 0D 01 01 20 01 00 C9 00 73 )
[2019-04-16 20:25:25.227] [D] [zway] SENT ACK
[2019-04-16 20:25:25.227] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2019-04-16 20:25:25.227] [D] [zway] SETDATA devices.1.instances.1.commandClasses.32.data.srcNodeId = 5 (0x00000005)
[2019-04-16 20:25:25.227] [D] [zway] SETDATA devices.1.instances.1.commandClasses.32.data.srcInstanceId = 1 (0x00000001)
[2019-04-16 20:25:25.227] [D] [zway] SETDATA devices.1.instances.1.commandClasses.32.data.level = 0 (0x00000000)
[2019-04-16 20:25:25.227] [D] [zway] SETDATA devices.5.instances.1.commandClasses.48.data.1.level = False
[2019-04-16 20:25:25.227] [D] [zway] SETDATA devices.5.instances.1.commandClasses.48.data.1 = Empty
[2019-04-16 20:25:25.230] [core] [BaseModule-31] Set lastLevel to off for ZWayVDev_zway_Remote_5-1-1-B (was on)
[2019-04-16 20:25:25.297] [core] --- ZWayVDev_zway_10-0-38 performCommand processing: {"0":"exact"
[2019-04-16 20:25:25.297] [zway] Adding job: SwitchMultilevel Set
[2019-04-16 20:25:25.298] [zway] Adding job: SwitchMultilevel Get
[2019-04-16 20:25:25.298] [core] [BaseModule-31] Set lastLevel to off for ZWayVDev_zway_5-1-48-1 (was on)
[2019-04-16 20:25:25.299] [D] [zway] SENDING (cb 0x50): ( 01 0B 00 13 0A 04 26 01 41 FF 25 50 05 )
[2019-04-16 20:25:25.301] [D] [zway] RECEIVED ACK
[2019-04-16 20:25:25.305] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-04-16 20:25:25.305] [D] [zway] SENT ACK
[2019-04-16 20:25:25.305] [D] [zway] Delivered to Z-Wave stack
[2019-04-16 20:25:25.329] [D] [zway] RECEIVED: ( 01 18 00 13 50 00 00 02 00 BB 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 1C )
[2019-04-16 20:25:25.329] [D] [zway] SENT ACK
[2019-04-16 20:25:25.329] [zway] Job 0x13 (SwitchMultilevel Set): Delivered
[2019-04-16 20:25:25.329] [D] [zway] SendData Response with callback 0x50 received: received by recipient
[2019-04-16 20:25:25.330] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2019-04-16 20:25:25.330] [D] [zway] SETDATA devices.10.data.lastSend = 17474801 (0x010aa4f1)
[2019-04-16 20:25:25.330] [D] [zway] Job 0x13 (SwitchMultilevel Set): success
[2019-04-16 20:25:25.330] [zway] Removing job: SwitchMultilevel Set
[2019-04-16 20:25:25.370] [D] [zway] SENDING (cb 0x51): ( 01 09 00 13 0A 02 26 02 25 51 BD )
[2019-04-16 20:25:25.371] [D] [zway] RECEIVED ACK
[2019-04-16 20:25:25.375] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-04-16 20:25:25.375] [D] [zway] SENT ACK
[2019-04-16 20:25:25.375] [D] [zway] Delivered to Z-Wave stack
[2019-04-16 20:25:25.378] [core] Notification: device-info (device-OnOff): {"dev":"Fibaro (5.1.1) Button"
[2019-04-16 20:25:25.401] [D] [zway] RECEIVED: ( 01 18 00 13 51 00 00 02 00 BB 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 1D )
[2019-04-16 20:25:25.402] [D] [zway] SENT ACK
[2019-04-16 20:25:25.402] [I] [zway] Job 0x13 (SwitchMultilevel Get): Delivered
[2019-04-16 20:25:25.403] [D] [zway] SendData Response with callback 0x51 received: received by recipient
[2019-04-16 20:25:25.403] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2019-04-16 20:25:25.403] [D] [zway] SETDATA devices.10.data.lastSend = 17474808 (0x010aa4f8)
[2019-04-16 20:25:25.403] [D] [zway] Job 0x13 (SwitchMultilevel Get): success
[2019-04-16 20:25:25.403] [I] [zway] Waiting for job reply: SwitchMultilevel Get
[2019-04-16 20:25:25.441] [D] [zway] RECEIVED: ( 01 0B 00 04 00 0A 03 26 03 41 BB 00 26 )
[2019-04-16 20:25:25.441] [D] [zway] SENT ACK
[2019-04-16 20:25:25.441] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2019-04-16 20:25:25.441] [D] [zway] Received reply on job (SwitchMultilevel Get)
[2019-04-16 20:25:25.441] [D] [zway] SETDATA devices.10.instances.0.commandClasses.38.data.level = 65 (0x00000041)
[2019-04-16 20:25:25.465] [I] [core] --- ZWayVDev_zway_10-0-38 performCommand processing: {"0":"exact"
[2019-04-16 20:25:25.465] [I] [zway] Adding job: SwitchMultilevel Set
[2019-04-16 20:25:25.465] [I] [zway] Adding job: SwitchMultilevel Get
[2019-04-16 20:25:25.466] [I] [core] Notification: device-info (device-status): {"dev":"Tak-Fläkt Dimmer (10.0)"
[2019-04-16 20:25:25.471] [D] [zway] SENDING (cb 0x52): ( 01 0B 00 13 0A 04 26 01 41 FF 25 52 07 )
[2019-04-16 20:25:25.473] [D] [zway] RECEIVED ACK
[2019-04-16 20:25:25.477] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-04-16 20:25:25.477] [D] [zway] SENT ACK
[2019-04-16 20:25:25.477] [D] [zway] Delivered to Z-Wave stack
[2019-04-16 20:25:25.501] [D] [zway] RECEIVED: ( 01 18 00 13 52 00 00 02 00 BB 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 1E )
[2019-04-16 20:25:25.501] [D] [zway] SENT ACK
[2019-04-16 20:25:25.501] [I] [zway] Job 0x13 (SwitchMultilevel Set): Delivered
[2019-04-16 20:25:25.501] [D] [zway] SendData Response with callback 0x52 received: received by recipient
[2019-04-16 20:25:25.501] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2019-04-16 20:25:25.502] [D] [zway] SETDATA devices.10.data.lastSend = 17474818 (0x010aa502)
[2019-04-16 20:25:25.502] [D] [zway] Job 0x13 (SwitchMultilevel Set): success
[2019-04-16 20:25:25.502] [I] [zway] Removing job: SwitchMultilevel Set
[2019-04-16 20:25:25.514] [I] [core] [BaseModule-31] Set lastLevel to 65 for ZWayVDev_zway_10-0-38 (was 75)
[2019-04-16 20:25:25.541] [D] [zway] SENDING (cb 0x53): ( 01 09 00 13 0A 02 26 02 25 53 BF )
[2019-04-16 20:25:25.543] [D] [zway] RECEIVED ACK
[2019-04-16 20:25:25.547] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-04-16 20:25:25.547] [D] [zway] SENT ACK
[2019-04-16 20:25:25.547] [D] [zway] Delivered to Z-Wave stack
[2019-04-16 20:25:25.562] [D] [zway] Job 0x13: deleted from queue
[2019-04-16 20:25:25.573] [D] [zway] RECEIVED: ( 01 18 00 13 53 00 00 02 00 B9 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 1D )
[2019-04-16 20:25:25.573] [D] [zway] SENT ACK
[2019-04-16 20:25:25.573] [I] [zway] Job 0x13 (SwitchMultilevel Get): Delivered
[2019-04-16 20:25:25.573] [D] [zway] SendData Response with callback 0x53 received: received by recipient
[2019-04-16 20:25:25.573] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2019-04-16 20:25:25.573] [D] [zway] SETDATA devices.10.data.lastSend = 17474825 (0x010aa509)
[2019-04-16 20:25:25.573] [D] [zway] Job 0x13 (SwitchMultilevel Get): success
[2019-04-16 20:25:25.573] [I] [zway] Waiting for job reply: SwitchMultilevel Get
[2019-04-16 20:25:25.604] [D] [zway] RECEIVED: ( 01 0B 00 04 00 0A 03 26 03 41 BB 00 26 )
[2019-04-16 20:25:25.604] [D] [zway] SENT ACK
[2019-04-16 20:25:25.604] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2019-04-16 20:25:25.604] [D] [zway] Received reply on job (SwitchMultilevel Get)
[2019-04-16 20:25:25.604] [D] [zway] SETDATA devices.10.instances.0.commandClasses.38.data.level = 65 (0x00000041)
Post by PoltoS » 19 Apr 2019 22:42
Looks like the device is only sending Set events, while replies on Get with a Report. I think you should check for config params to configure Reports properly.
