buster image can't get wi-fi to work
doubledrat
Post by doubledrat » 17 Nov 2019 20:40
Hi
I'm using the z-wave buster image and I can't get wifi to work. I've tried two different cards and multiple configurations.
the same hardware with vanilla buster (light) works first time.
any idea what you've done to the image to prevent wifi working?
one of the adapters I've tried is an edimax. not sure what the other one is.
If I ping the pi while it's booting, it comes on the network briefly (3-4 pings) then falls off the network again.
ideas?
thanks
aivs
Re: buster image can't get wi-fi to work
Post by aivs » 18 Nov 2019 00:42
Hi!
Try different usb cable and power adapter.
I think the problem with power, I've seen the like.
doubledrat
Post by doubledrat » 23 Nov 2019 13:11
thanks for the suggestion, but as I said, the same hardware with a clean buster image works fine. it's only with the one provided by zwave that doesn't work, so it can't be the power.
doubledrat
Post by doubledrat » 11 Dec 2019 12:37
no ideas?
I'm having to use it wired at the moment which is not at all convenient...
aivs
Post by aivs » 20 Dec 2019 15:06
What is the RPi model?
aivs
Post by aivs » 20 Dec 2019 16:48
Today I tested with RPi 3B+, wi-fi works
