https login via nginx start failing
jet11x
Post by jet11x » 21 Dec 2019 19:53
I've had secure https login via nginx as a reverse proxy for some time, but some time ago it stopped working.
Taking a closer look at it, I'm getting an error:
SmartHome UI - ERROR
User not found. Please check your login or password.
I'm not sure why it would differently to local use. I can't find a log that shows the problem.
Any suggestions?
jet11x
Re: https login via nginx start failing
Post by jet11x » 22 Dec 2019 16:42
I've found a solution which is added the following line:
proxy_set_header        Authorization "";
in the nginx config
