Cannot start Z-Wave binding: Error: Binding with name 'zway' already exists
Re: Cannot start Z-Wave binding: Error: Binding with name 'zway' already exists
Make sure it is on ACM0 and not on ACM1 (if you unplugged it). Please show logs
Clubber2000
Post by Clubber2000 »
It is on ACM0 and it worked now for some days until this evening about 6.20 pm.
The z way server and also the whole raspberry was not reachable anymore. After a restart of the raspberry the binding problem was not there but the question is: what was the reason for the error.
I attached the logfile.
z-way-server-short.rar
(375.48 KiB) Downloaded 309 times
It crashed at 18:20. It is a know error. We have a fix.
Please install it using
cd /tmp && wget https://storage.z-wave.me/z-way-server/ ... _armhf.deb && sudo dpkg -i z-way-3.0.4-33-gfb22f31_armhf.deb
Hope it will work for you until we release next stable version.
Clubber2000
Thanks a lot.
I installed the patch right now.
I hope the shutdowns will not happen again.
Clubber2000
The patch improved the stability of the system. But after a while last night my z way system went down without any reason for me.
I attached the log file for further investments if anybody could help.
It happened between the 11. and 12. February in the night. I think 3.17am. In the morning I recognized the not working system and restarted it manually by switching off and on at about 6.30 am.
(542.8 KiB) Downloaded 292 times
We are checking it.
