[SOLVED] Help updating the firmware after successfully updating the bootloader
Converseallstar95
I have a RaZBerry, Pi B3+ and installed the Z-Way.img, When I navigated to the expert Z-Wave UI, I was able to update the bootloader from 5.04 to 8aaa, and it showed that I could update the firmware to 5.07. After I updated the bootlader and rebooted, the 5.07 update was no longer there? I've found many people here updating through terminal, how do I access the terminal through the web UI? Thanks!
Re: Help updating the firmware after successfully updating the bootloader
Enter token "all" and get more options
Converseallstar95
Thanks for the help, but nothing changed when I typed all and hit go?
Your Z-Way us 3.0.x? Your RaZ is 5.07?
Converseallstar95
Z-Way is 3.0.3 and RaZ last showed 5.04.
Make sure to update the bootloader first. Does it show you this button? What is proposed?
Converseallstar95
When I first went to the updating webpage, there was a bootloader update (5.04 to 8aaa) and a firmware update (5.04 to 5.07). After updating the bootloader, the firmware update does not show up.
Please make sure your firmware CRC is no 8aaa (35498 in decomal in the UI), your Z-Way is 3.0.x, your uuid is not 0x00000000000000 (in that case just power off the full Pi and tunr on again).
The transition file is online:
https://service.z-wave.me/expertui/uzb- ... tml?hw=327
Converseallstar95
My UUID did have all 0's, so when I unplugged the Pi and plugged it back in, I now see an update for 5.04 to 5.07 and 5.04 to 5.22; thanks!
I upgraded 5.04 > 5.07 > 5.22 > 5.23 > 5.32 > 5.36
Marked as solved!
Marked as solved!
Re: [SOLVED] Help updating the firmware after successfully updating the bootloader
In the expert Z-Wave UI, did you go to Network -> Controller Info and then the button Firmware Update?
In my case, I get a Z-Wave Expert UI - ERROR message saying Could not retrieve data from remote server.
I noticed the Access Token looks empty, should something be filled?
