action of scene depending on switch state
HeHa
Post by HeHa » 08 Feb 2020 15:22
I use EventWatcher to turn off lights based on Astronomy and Presence modules.
I want to turn off another switch (TV) 5 minutes later if the lights are still off.
How to implement? Logical Rule module should be able to, but does not work for me.
/HeHa
Re: action of scene depending on switch state
Post by PoltoS » 09 Feb 2020 11:06
There is a delayed scene app. You can trigger it from other apps
HeHa
Post by HeHa » 09 Feb 2020 17:26
PoltoS wrote:
09 Feb 2020 11:06
Yes thank you. What I am then missing is the dependency of the light switch?
/HeHa
Post by PoltoS » 15 Feb 2020 17:03
You can use logical rules to trigger scene on button press
HeHa
Post by HeHa » 19 Feb 2020 00:23
when scene is triggered, I want to turn off device B but only if device A is off.
micky1500
Post by micky1500 » 19 Feb 2020 02:57
This is how I would do it.
it might work :)
Create 2 App - Dummy Devices
Binary Switch DummyA and DummyB
Create App - Automated Switch Off
Switch off DummyA after 300 seconds
Create Rule in 'Automation-Rules' Add. New.
IF - (Turn on Advanced settings at bottom)
Nested Condition (AND)
if DummyA = Off (5 minutes has expired)
if DummyB = On (EventWatcher was triggered)
if Lights = Off (Lights are off)
THEN
Turn OFF DummyB
Turn OFF TV
ELSE
Disable Reverse Event
In EventWatcher
Turn Off Lights (as already doing)
Also in same Event
Turn On DummyA
Turn On DummyB
DummyB is used to prevent normal light switching on/off from triggering false TV changes.
Does seem a bit complicated to turn off a TV tho.
Micky
Raspi 4(Buster), Zwave Version 3.0.4
