ZWay/Razberry 7 pro crashing on semi-included device
CorC
Post by CorC »
I have this weird issue, where during the inclusion of a mini dimmer with smart start, it appeared to end up in an inclusion loop, where a device 10, 11 etc were created. I then unplugged the device I was including from power, which stopped the proces.
I was able to include additional devices afterwards, however before attempting to re-include the device causing the initial issue, I tried to clean up.
I can't however remove device 10. It is in state "interview incomplete" where appearantly according to the zway expert interface only the S2 part completes. When I try to call for NIF, it would say the device is still alive, however, when examining the logs, I notice the chip crashes everytime it tries to send a NIF for device 10. I think something got corrupted, and am in need of some help, since I can't get the device in "fail" state, I can't remove it either.
Is there any way to tell zway the device is dead, so I can attempt to remove it from the network without it trying to send a packet?
(P.S. rebooting, and cutting power to the controller didn't help/change anything, the issue remains)
This is what the logs show:
[2023-01-30 22:50:45.033] [zway] Adding job: Request NIF from a node to node 10
[2023-01-30 22:50:45.041] [D] [zway] SENDING: ( 01 04 00 60 0A 91 )
[2023-01-30 22:50:45.043] [D] [zway] RECEIVED ACK
[2023-01-30 22:50:45.044] [D] [zway] RECEIVED: ( 01 04 01 60 01 9B )
[2023-01-30 22:50:45.044] [D] [zway] SENT ACK
[2023-01-30 22:50:45.044] [zway] Job 0x60 (Request NIF from a node to node 10): Request for node 10 information frame sent
[2023-01-30 22:50:46.321] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 00 00 00 00 00 01 01 01 01 FF FF 00 00 A8 1C 00 20 38 00 00 00 00 00 81 E2 00 00 81 E2 8C 00 00 C4 22 32 00 20 00 00 00 00 80 20 00 20 78 30 00 20 8C 00 00 00 AC 1C 00 20 01 00 00 00 EA 5F 00 20 FD )
[2023-01-30 22:50:46.321] [D] [zway] SENT ACK
[2023-01-30 22:50:46.328] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 00 00 70 07 00 01 9B 00 00 00 00 00 00 00 02 05 00 78 30 00 20 8C 00 00 01 01 00 00 00 F7 5A 00 20 00 00 00 00 09 00 00 00 02 00 00 00 8B 85 01 00 D3 96 01 02 07 60 19 1B 73 31 00 00 00 00 00 00 EF )
[2023-01-30 22:50:46.328] [D] [zway] SENT ACK
[2023-01-30 22:50:46.333] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 D3 9C 01 10 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE D3 9C 01 11 01 00 00 00 00 00 3F )
[2023-01-30 22:50:46.334] [D] [zway] SENT ACK
[2023-01-30 22:50:46.340] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE D3 9C 01 11 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE FE D3 9C 01 67 )
[2023-01-30 22:50:46.341] [D] [zway] SENT ACK
[2023-01-30 22:50:46.346] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 01 10 01 A1 01 18 70 00 00 00 00 00 00 F7 5A 00 20 01 00 00 00 C2 00 00 00 09 00 00 00 B5 3E 01 00 01 00 00 00 EB 55 01 00 EA 5F 00 20 69 A9 01 00 83 60 00 20 09 00 00 00 B0 5F 00 20 00 00 00 00 B3 )
[2023-01-30 22:50:46.346] [D] [zway] SENT ACK
[2023-01-30 22:50:46.353] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 01 02 00 00 00 44 60 00 20 09 00 00 00 E1 AB 01 00 32 81 04 00 0A 00 00 00 01 00 00 00 00 00 00 00 02 00 00 00 24 32 00 20 0A 00 00 00 00 00 00 00 24 32 00 20 0D 00 00 00 22 32 00 20 84 60 00 20 01 )
[2023-01-30 22:50:46.353] [D] [zway] SENT ACK
[2023-01-30 22:50:46.359] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 01 0A 00 00 00 86 60 00 20 70 39 00 20 4B AC 01 00 24 32 00 20 85 60 00 20 00 00 00 00 00 00 00 00 45 60 00 20 AF B3 01 00 00 00 00 00 AB 7D 04 00 0A 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 B2 )
[2023-01-30 22:50:46.359] [D] [zway] SENT ACK
[2023-01-30 22:50:46.366] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 01 00 00 00 00 00 00 00 00 24 32 00 20 22 32 00 20 83 60 00 20 45 60 00 20 70 39 00 20 73 B4 01 00 22 32 00 20 80 4D 00 20 00 00 00 00 30 49 00 20 0A 00 00 00 43 47 00 20 00 00 00 00 A5 A5 A5 A5 4D )
[2023-01-30 22:50:46.366] [D] [zway] SENT ACK
[2023-01-30 22:50:46.373] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 02 A5 A5 A5 A5 BF FD 00 00 23 32 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 02 00 00 00 A4 4D 00 20 04 00 00 00 01 00 00 00 A5 A5 A5 A5 A5 A5 A5 A5 A7 AD 00 00 F4 )
[2023-01-30 22:50:46.373] [D] [zway] SENT ACK
[2023-01-30 22:50:46.378] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 02 8D 27 01 00 FF 7F 00 00 60 39 00 20 07 00 00 00 80 00 00 00 D1 A8 00 00 FF FF FF FF 70 70 00 20 00 00 00 00 80 00 00 00 38 33 00 20 30 3A 00 20 98 5A 00 20 9C 5A 00 20 C4 39 00 20 3F B9 00 00 59 )
[2023-01-30 22:50:46.379] [D] [zway] SENT ACK
[2023-01-30 22:50:46.385] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 02 A5 A5 A5 A5 D3 96 01 02 07 A5 A5 A5 00 01 00 7F 1E 00 8C 00 3A 6F 00 20 81 B5 00 00 1D B5 00 00 F5 B5 00 00 CD B4 00 00 C4 39 00 20 00 00 00 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 CE )
[2023-01-30 22:50:46.386] [D] [zway] SENT ACK
[2023-01-30 22:50:46.391] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 02 A5 A5 A5 A5 47 3D 00 00 A5 A5 A5 A5 6C 30 00 20 00 00 00 00 90 17 00 20 90 17 00 20 D4 32 00 20 88 17 00 20 0B 00 00 00 B0 18 00 20 B0 18 00 20 D4 32 00 20 00 00 00 00 2D 00 00 00 D4 20 00 20 C0 )
[2023-01-30 22:50:46.391] [D] [zway] SENT ACK
[2023-01-30 22:50:46.398] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 03 5A 2D 57 61 76 65 20 00 00 00 00 00 02 00 00 00 00 00 00 00 2D 00 00 00 00 00 00 00 80 00 00 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 58 56 00 20 00 01 00 00 08 7D 02 00 07 00 00 00 C8 )
[2023-01-30 22:50:46.398] [D] [zway] SENT ACK
[2023-01-30 22:50:46.404] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 03 64 3C 00 20 14 3C 00 20 30 3B 00 20 9C 3B 00 20 C4 39 00 20 A8 81 02 00 F0 3B 00 20 EC 3B 00 20 00 3C 00 20 DC 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 28 01 00 20 00 00 00 00 A5 A5 A5 A5 F4 )
[2023-01-30 22:50:46.404] [D] [zway] SENT ACK
[2023-01-30 22:50:46.411] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 03 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 CA )
[2023-01-30 22:50:46.411] [D] [zway] SENT ACK
[2023-01-30 22:50:46.416] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 03 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 8A )
[2023-01-30 22:50:46.416] [D] [zway] SENT ACK
[2023-01-30 22:50:46.423] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 04 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 4D )
[2023-01-30 22:50:46.423] [D] [zway] SENT ACK
[2023-01-30 22:50:46.430] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 04 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 0D )
[2023-01-30 22:50:46.431] [D] [zway] SENT ACK
[2023-01-30 22:50:46.436] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 04 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 CD )
[2023-01-30 22:50:46.436] [D] [zway] SENT ACK
[2023-01-30 22:50:46.443] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 04 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 8D )
[2023-01-30 22:50:46.443] [D] [zway] SENT ACK
[2023-01-30 22:50:46.450] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 05 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 4C )
[2023-01-30 22:50:46.450] [D] [zway] SENT ACK
[2023-01-30 22:50:46.456] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 05 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 00 00 00 00 68 1C 00 20 7F 1C 00 20 4C 1C 00 20 01 00 00 00 14 1A 00 20 14 1A 00 20 4B 01 00 00 0D 7B 00 00 56 )
[2023-01-30 22:50:46.456] [D] [zway] SENT ACK
[2023-01-30 22:50:46.461] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 05 A9 A4 00 00 DF 75 00 00 14 1A 00 20 14 1A 00 20 20 00 00 00 0D 7B 00 00 14 1A 00 20 E4 00 00 20 00 E0 00 E0 00 00 00 10 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 FD FF FF FF C5 )
[2023-01-30 22:50:46.461] [D] [zway] SENT ACK
[2023-01-30 22:50:46.468] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 05 00 20 05 40 00 00 00 80 01 00 00 00 01 1C 00 80 A5 A5 A5 A5 33 A8 00 00 26 7F 00 00 00 00 00 81 04 14 00 20 FF 4E 00 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 47 3D 00 00 A5 A5 A5 A5 A5 A5 A5 A5 4D )
[2023-01-30 22:50:46.468] [D] [zway] SENT ACK
[2023-01-30 22:50:46.475] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 06 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 4F )
[2023-01-30 22:50:46.475] [D] [zway] SENT ACK
[2023-01-30 22:50:46.481] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 06 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 0F )
[2023-01-30 22:50:46.481] [D] [zway] SENT ACK
[2023-01-30 22:50:46.488] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 06 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 CF )
[2023-01-30 22:50:46.488] [D] [zway] SENT ACK
[2023-01-30 22:50:46.494] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 06 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 8F )
[2023-01-30 22:50:46.494] [D] [zway] SENT ACK
[2023-01-30 22:50:46.501] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 07 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 4E )
[2023-01-30 22:50:46.501] [D] [zway] SENT ACK
[2023-01-30 22:50:46.506] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 07 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 0E )
[2023-01-30 22:50:46.506] [D] [zway] SENT ACK
[2023-01-30 22:50:46.513] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 07 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 CE )
[2023-01-30 22:50:46.513] [D] [zway] SENT ACK
[2023-01-30 22:50:46.519] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 07 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 74 18 00 20 EC 38 00 20 B0 4D 00 20 00 00 04 00 68 18 00 20 00 00 00 00 DC 18 00 20 E0 19 00 20 82 )
[2023-01-30 22:50:46.519] [D] [zway] SENT ACK
[2023-01-30 22:50:46.524] [D] [zway] RECEIVED: ( 01 36 00 F8 08 00 01 02 11 07 05 00 00 00 00 00 00 00 00 38 ED 00 E0 00 00 00 00 01 01 01 01 FF FF 00 00 A8 1C 00 20 18 00 00 00 01 9B 00 00 00 9B 00 00 00 00 00 61 F0 )
[2023-01-30 22:50:46.524] [D] [zway] SENT ACK
[2023-01-30 22:50:46.524] [D] [zway] Firmware started. Version 7.17.2.1
[2023-01-30 22:50:46.524] [D] [zway] Firmware failure 07
[2023-01-30 22:50:46.741] [D] [zway] RECEIVED: ( 01 10 00 0A 07 00 03 02 07 06 5E 98 9F 6C 56 55 00 D4 )
[2023-01-30 22:50:46.741] [D] [zway] SENT ACK
[2023-01-30 22:50:46.742] [zway] Z-Wave chip restart
[2023-01-30 22:50:46.742] [zway] - Wakeup reason: Software reset
[2023-01-30 22:50:46.742] [zway] - WatchDog: started
[2023-01-30 22:50:46.742] [zway] - Long Range: not supported
[2023-01-30 22:50:46.742] [zway] Adding job: Configure Serial API features
[2023-01-30 22:50:46.742] [zway] Adding job: WatchDog Start
[2023-01-30 22:50:46.742] [zway] Adding job: Enable Smart Start
[2023-01-30 22:50:46.742] [D] [zway] SENDING: ( 01 05 00 0B 80 01 70 )
[2023-01-30 22:50:46.744] [D] [zway] RECEIVED ACK
[2023-01-30 22:50:46.744] [D] [zway] RECEIVED: ( 01 05 01 0B 80 01 71 )
[2023-01-30 22:50:46.744] [D] [zway] SENT ACK
[2023-01-30 22:50:46.744] [D] [zway] SETDATA controller.data.longRange.enabled = False
[2023-01-30 22:50:46.744] [zway] Job 0x0b (Configure Serial API features): Done
[2023-01-30 22:50:46.744] [D] [zway] Job 0x0b (Configure Serial API features): success
[2023-01-30 22:50:46.744] [I] [zway] Removing job: Configure Serial API features
[2023-01-30 22:50:46.744] [D] [zway] SENDING: ( 01 03 00 D2 2E )
[2023-01-30 22:50:46.745] [D] [zway] RECEIVED ACK
[2023-01-30 22:50:46.745] [I] [zway] Removing job: WatchDog Start
[2023-01-30 22:50:55.349] [D] [zway] Job 0x3b: deleted from queue
[2023-01-30 22:51:00.659] [D] [zway] Job 0x13: deleted from queue
[2023-01-30 22:51:00.833] [D] [zway] Job 0x13: deleted from queue
[2023-01-30 22:51:01.641] [D] [zway] Job 0x13: deleted from queue
[2023-01-30 22:51:01.743] [D] [zway] Job 0x13: deleted from queue
[2023-01-30 22:51:01.876] [D] [zway] Job 0x13: deleted from queue
[2023-01-30 22:51:05.085] [I] [zway] Adding job: Get background noise level
[2023-01-30 22:51:05.308] [I] [zway] Job 0x60 (Request NIF from a node to node 10): Job not removed after RESPONSE received
[2023-01-30 22:51:05.308] [D] [zway] SENDING: ( 01 04 00 60 0A 91 )
[2023-01-30 22:51:05.310] [D] [zway] RECEIVED ACK
[2023-01-30 22:51:05.311] [D] [zway] RECEIVED: ( 01 04 01 60 01 9B )
[2023-01-30 22:51:05.311] [D] [zway] SENT ACK
[2023-01-30 22:51:05.312] [I] [zway] Job 0x60 (Request NIF from a node to node 10): Request for node 10 information frame sent
[2023-01-30 22:51:06.588] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 00 80 20 00 20 78 30 00 20 8C 00 00 00 AC 1C 00 20 0D 00 00 00 EA 5F 00 20 00 70 07 00 01 9B 00 00 00 00 00 00 03 02 05 00 78 30 00 20 8C 00 00 01 0D 00 00 00 F7 5A 00 20 0C 00 00 00 11 00 00 00 B4 )
[2023-01-30 22:51:06.589] [D] [zway] SENT ACK
[2023-01-30 22:51:06.595] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 00 78 59 00 20 73 85 01 00 D3 9C 01 10 01 11 04 10 11 81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE D3 9C 01 11 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 95 )
[2023-01-30 22:51:06.596] [D] [zway] SENT ACK
[2023-01-30 22:51:06.601] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE D3 9C 01 11 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE D3 9C 01 11 01 00 00 00 00 00 00 00 00 00 00 C9 )
[2023-01-30 22:51:06.601] [D] [zway] SENT ACK
[2023-01-30 22:51:06.608] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE FE D3 9C 01 10 01 81 09 12 50 00 00 00 00 00 00 F7 5A 00 20 10 00 00 00 C2 00 00 00 11 00 00 00 B5 3E 01 00 10 00 00 00 EB 55 01 00 77 )
[2023-01-30 22:51:06.608] [D] [zway] SENT ACK
[2023-01-30 22:51:06.614] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 01 EA 5F 00 20 69 A9 01 00 83 60 00 20 11 00 00 00 CD 5F 00 20 01 00 00 00 03 00 00 00 45 60 00 20 11 00 00 00 E1 AB 01 00 42 4C 00 00 0A 00 00 00 01 00 00 00 00 00 00 00 03 00 00 00 24 32 00 20 11 )
[2023-01-30 22:51:06.614] [D] [zway] SENT ACK
[2023-01-30 22:51:06.621] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 01 00 00 00 00 00 00 00 00 24 32 00 20 12 00 00 00 22 32 00 20 84 60 00 20 0A 00 00 00 86 60 00 20 70 39 00 20 4B AC 01 00 24 32 00 20 85 60 00 20 00 00 00 00 00 00 00 00 45 60 00 20 AF B3 01 00 70 )
[2023-01-30 22:51:06.621] [D] [zway] SENT ACK
[2023-01-30 22:51:06.626] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 01 00 00 00 00 F4 48 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 24 32 00 20 22 32 00 20 83 60 00 20 45 60 00 20 70 39 00 20 73 B4 01 00 22 32 00 20 80 4D 00 20 C6 )
[2023-01-30 22:51:06.627] [D] [zway] SENT ACK
[2023-01-30 22:51:06.633] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 01 00 00 00 00 30 49 00 20 0A 00 00 00 43 47 00 20 00 00 00 00 A5 A5 A5 A5 A5 A5 A5 A5 BF FD 00 00 23 32 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 02 00 00 00 86 )
[2023-01-30 22:51:06.634] [D] [zway] SENT ACK
[2023-01-30 22:51:06.640] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 02 A4 4D 00 20 04 00 00 00 01 00 00 00 A5 A5 A5 A5 A5 A5 A5 A5 A7 AD 00 00 8D 27 01 00 FF 7F 00 00 60 39 00 20 07 00 00 00 80 00 00 00 D1 A8 00 00 FF FF FF FF 70 70 00 20 00 00 00 00 80 00 00 00 81 )
[2023-01-30 22:51:06.641] [D] [zway] SENT ACK
[2023-01-30 22:51:06.646] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 02 38 33 00 20 30 3A 00 20 98 5A 00 20 9C 5A 00 20 C4 39 00 20 3F B9 00 00 A5 A5 A5 A5 D3 96 01 02 07 A5 A5 A5 00 01 00 7F 1E 00 8C 00 3A 6F 00 20 81 B5 00 00 1D B5 00 00 F5 B5 00 00 CD B4 00 00 8D )
CONTROLLER DEVICE DATA:
/: None (22.08.2020)
basicType: 2 (22:15)
genericType: 2 (22:15)
specificType: 7 (22:15)
infoProtocolSpecific: 13866497 (22:15)
deviceTypeString: Static Controller (22:15)
isVirtual: false (22.08.2020)
isListening: true (22:15)
isRouting: true (22:15)
isAwake: false (22.08.2020)
optional: true (22:15)
isFailed: false (22.08.2020)
sensor250: false (22:15)
sensor1000: false (22:15)
neighbours: 6,7,9,12,13,17,18,20,21,25,26,29,30,31,33,37,38 (22:46)
multicastGroup: 0 (18.02.2021)
manufacturerId: 277 (22:15)
vendorString: (22.08.2020)
productString: (26.09.2021)
manufacturerProductType: 1 (22:15)
manufacturerProductId: 1025 (22:15)
ZWLib: 0 (22.08.2020)
ZWProtocolMajor: 0 (22.08.2020)
ZWProtocolMinor: 0 (22.08.2020)
SDK: (22.08.2020)
applicationMajor: 4 (22:15)
applicationMinor: 0 (22:15)
installerIcon: 1280 (22:15)
userIcon: 1280 (22:15)
nodeInfoFrame: 94,152,159,108,86,85 (22:15)
ZDDXMLFile: (22.08.2020)
lastSend: 0 (22:15)
lastNonceGet: None (22:15)
lastReceived: 0 (22.08.2020)
failureCount: 0 (22:15)
keepAwake: false (22.08.2020)
queueLength: 0 (22.08.2020)
priorityRoutes: None (22.08.2020)
givenName: (22.08.2020)
interviewDone: false (22.08.2020)
acceptSetSecurityLevel: None (18.02.2021)
acceptReportSecurityLevel: None (28.01.2023)
mapBasicSetToSpecificReport: false (28.01.2023)
unsolicitedReportOnSet: 0 (26.09.2021)
securityS2ExchangedKeys: 0 (22.08.2020)
secureChannelEstablished: true (22.08.2020)
guessS2Keys: false (11.04.2022)
secureControllerId: 1 (22.08.2020)
publicKey: **,** masked (22:21)
joiningS2: false (22:15)
*CONTROLLER DATA*:
/: None (22:15)
nodeId: 1 (22:15)
homeId: -*** masked(22:15)
SUCNodeId: 1 (22:15)
isPrimary: true (22:15)
isInOthersNetwork: false (22:15)
isRealPrimary: true (22:15)
isSUC: true (22:15)
SISPresent: true (22:15)
libType: Static Controller (22:15)
SDK: 7.17.00 (22:15)
ZWlibMajor: 7 (22:15)
ZWlibMinor: 17 (22:15)
ZWLib: 1 (22:15)
ZWVersion: 9 (22:15)
ZWaveChip: ZW0700 (22:15)
APIVersion: 07.28 (22:15)
APIVersionMajor: 7 (22:15)
APIVersionMinor: 28 (22:15)
manufacturerId: 327 (22:15)
vendor: RaZberry by Z-Wave.Me (22:15)
manufacturerProductType: 1025 (22:15)
manufacturerProductId: 257 (22:15)
capabilities: 2,3,4,5,6,7,8,9,10,11,16,18,19,20,21,22,28,32,33,34,35,36,39,40,41,42,43,44,45,46,55,56,57,58,59,60,63,65,66,68,69,70,71,72,73,74,75,77,79,80,81,83,84,85,86,87,88,94,95,96,97,98,99,128,144,146,147,152,160,162,164,165,166,168,169,171,189,190,191,208,209,210,211,212,214,217,218,219,220,221,222,223,242,244,245,246,247,248 (22:15)
controllerState: 0 (22:21)
nonManagmentJobs: 0 (22:15)
lastIncludedDevice: 31 (22:21)
lastExcludedDevice: None (22:21)
secureInclusion: 2 (22:15)
oldSerialAPIAckTimeout10ms: 220 (22:15)
oldSerialAPIByteTimeout10ms: 150 (22:15)
curSerialAPIAckTimeout10ms: 10 (22:15)
curSerialAPIByteTimeout10ms: 10 (22:15)
countJobs: false (22:15)
memoryGetAddress: 32768 (22:15)
memoryGetData: 84,223,222,103,161,39,63,12,147,216,192,24,4,17,163,221,148,194,86,120,62,18,10,184,40,179,155,109,62,244,157,244,104,25,51,110,165,148,66,130,124,116,57,97,4,70,181,172,36,231,181,170,90,109,197,96,220,231,185,110,128,91,184,79 (22:15)
memoryManufacturerId: None (22:15)
memoryType: None (22:15)
memoryCapacity: None (22:15)
functionClasses: 2,3,4,5,6,7,8,10,11,18,19,20,21,22,23,32,33,34,35,36,39,41,42,43,44,45,57,58,59,63,65,66,68,70,71,72,73,74,75,76,77,79,80,81,82,83,84,85,86,87,88,94,95,96,97,98,99,128,146,147,186,190,208,209,210,211,218,219,220,242,243,244,245,248 (22:15)
functionClassesNames: SerialAPIGetInitData,SerialAPIApplicationNodeInformation,ApplicationCommandHandler,GetControllerCapabilities,SerialAPISetTimeouts,GetSerialAPICapabilities,SerialAPISoftReset,SerialAPIStarted,SerialAPISetup,SendNodeInformation,SendData,SendDataMulti,GetVersion,SendDataAbort,RFPowerLevelSet,GetHomeId,MemoryGetByte,MemoryPutByte,MemoryGetBuffer,MemoryPutBuffer,FlashAutoProgSet,NVMGetId,NVMExtReadLongBuffer,NVMExtWriteLongBuffer,NVMExtReadLongByte,NVMExtWriteLongByte,ClearNetworkStats,GetNetworkStats,GetBackgroundRSSI,RemoveNodeIdFromNetwork,GetNodeProtocolInformation,SetDefault,ReplicationReceiveComplete,AssignReturnRoute,DeleteReturnRoute,RequestNodeNeighbourUpdate,ApplicationNodeUpdate,AddNodeToNetwork,RemoveNodeFromNetwork,CreateNewPrimary,ControllerChange,AssignPriorityReturnRoute,SetLearnMode,AssignSUCReturnRoute,EnableSUC,RequestNetworkUpdate,SetSUCNodeId,DeleteSUCReturnRoute,GetSUCNodeId,SendSUCNodeId,AssignPrioritySUC ReturnRoute,ExploreRequestInclusion,ExploreRequestExclusion,RequestNodeInformation,RemoveFailedNode,IsFailedNode,ReplaceFailedNode,GetRoutingTableLine,GetPriorityRoute,SetPriorityRoute,RFPowerLevelGet,SendTestFrame,SetPromiscuousMode,PromiscuousCommandHandler,WatchDogStart,WatchDogStop,GetLongRangeNodes,GetLongRangeChannel,SetLongRangeChannel,ZMEFreqChange,ZMERestore,ZMEBootloaderFlash,ZMECapabilities,ZMESerialAPIOptions (22:15)
softwareRevisionVersion: v4.0.2 (22:15)
softwareRevisionId: 0445874bba9f9ee7fd9dba8c8a52660764098ff5 (22:15)
softwareRevisionDate: 2022-12-25 18:20:13 +0300 (22:15)
uuid: 0000000000000000842e1******masked (22:15)
hardware: None (22:15)
programmerId: 842e14fffe6a2ceb (22:15)
productionSeq: 186 (19.05.2021)
uartSpeed: None (22:15)
bootloader: None (22:15)
version: 16779521 (22:15)
crc: 1766938484 (22:15)
firmware: None (22:15)
version: 0304.00000A26.1701 (14.06.2022)
build: 7.17.2/1 (14.06.2022)
crc: None (22:15)
caps: 1,21,255 (22:15)
crc: 42842 (22:15)
maxNodes: 255 (22:15)
staticApi: true (22:15)
maxPower: false (22:15)
backup: true (22:15)
wup: true (22:15)
advancedIMA: true (22:15)
longRange: false (22:15)
ultraUART: false (22:15)
swapSubvendor: false (22:15)
promisc: true (22:15)
zniffer: false (22:15)
jammingDetection: true (22:15)
pti: false (22:15)
modem: false (22:15)
fault: 5 (22:51)
scb: 0,0,0,0,0,0,0,0,56,237,0,224 (22:51)
reg: 0,0,0,0,1,1,1,1,255,255,0,0,168,28,0,32,56,0,0,0,1,155,0,0,0,155,0,0,0,0,0,97 (22:51)
stack: 0,0,0,0,1,88,255,255,128,32,0,32,140,0,0,0,40,49,0,32,0,1,129,226,0,1,129,226,140,0,0,192,34,50,0,32,0,0,0,0,128,32,0,32,120,48,0,32,140,0,0,0,172,28,0,32,9,0,0,0,234,95,0,32,112,7,0,1,155,0,0,0,0,0,0,2,2,5,0,120,48,0,32,140,0,0,1,9,0,0,0,247,90,0,32,8,0,0,0,17,0,0,0,2,0,0,0,139,133,1,0,211,156,1,17,1,33,8,154,16,32,0,0,0,0,0,0,73,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,254,211,156,1,17,1,0,0,16,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,254,211,156,1,17,1,0,16,0,0,160,105,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,254,211,156,1,16,1,161,1,24,112,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,254,254,211,156,1,174,1,129,9,18,80,0,0,0,0,0,0,247,90,0,32,9,0,0,0,194,0,0,0,17,0,0,0,181,62,1,0,9,0,0,0,235,85,1,0,234,95,0,32,105,169,1,0,131,96,0,32,17,0,0,0,205,95,0,32,1,0,0,0,205,0,0,0,69,96,0,32,17,0,0,0,225,171,1,0,70,76,0,0,10,0,0,0,1,0,0,0,0,0,0,0,3,0,0,0,36,50,0,32,0,0,0,0,0,0,0,0,36,50,0,32,18,0,0,0,34,50,0,32,132,96,0,32,176,0,0,0,134,96,0,32,112,57,0,32,75,172,1,0,36,50,0,32,133,96,0,32,0,0,0,0,0,0,0,0,69,96,0,32,175,179,1,0,0,0,0,0,249,72,0,0,10,0,0,0,0,0,0,0,0,0,0,0,10,0,0,0,209,0,0,0,0,0,0,0,36,50,0,32,34,50,0,32,131,96,0,32,69,96,0,32,112,57,0,32,115,180,1,0,34,50,0,32,128,77,0,32,0,0,0,0,48,73,0,32,10,0,0,0,67,71,0,32,0,0,0,0,165,165,165,165,77,165,165,165,191,253,0,0,35,50,0,32,0,0,0,0,0,0,0,0,0,0,0,0,0,8,0,0,0,0,0,0,0,0,0,0,2,0,0,0,164,77,0,32,4,0,0,0,1,0,0,0,165,165,165,165,165,165,165,165,167,173,0,0,244,39,1,0,255,127,0,0,96,57,0,32,7,0,0,0,128,0,0,0,209,168,0,0,255,255,255,255,112,112,0,32,0,0,0,0,128,0,0,0,56,51,0,32,48,58,0,32,152,90,0,32,156,90,0,32,196,57,0,32,63,185,0,0,89,165,165,165,211,150,1,2,7,165,165,165,0,1,0,127,30,0,140,0,58,111,0,32,129,181,0,0,29,181,0,0,245,181,0,0,205,180,0,0,196,57,0,32,0,0,0,0,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,206,165,165,165,71,61,0,0,165,165,165,165,132,47,0,32,0,0,0,0,144,23,0,32,144,23,0,32,212,50,0,32,136,23,0,32,11,0,0,0,176,24,0,32,176,24,0,32,212,50,0,32,0,0,0,0,45,0,0,0,212,32,0,32,55,45,87,97,118,101,32,0,0,0,0,0,2,0,0,0,0,0,0,0,45,0,0,0,0,0,0,0,128,0,0,0,2,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,88,86,0,32,0,1,0,0,8,125,2,0,7,0,0,0,200,60,0,32,20,60,0,32,48,59,0,32,156,59,0,32,196,57,0,32,168,129,2,0,240,59,0,32,236,59,0,32,0,60,0,32,50,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,40,1,0,32,0,0,0,0,165,165,165,165,26,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,202,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,138,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,77,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,13,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,205,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,141,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,76,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,0,0,0,0,104,28,0,32,127,28,0,32,76,28,0,32,1,0,0,0,20,26,0,32,20,26,0,32,80,1,0,0,13,123,0,0,77,164,0,0,223,117,0,0,20,26,0,32,228,0,0,32,0,224,0,224,0,0,0,16,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,253,255,255,255,128,32,0,32,0,0,0,128,0,0,0,128,2,0,0,0,17,165,165,165,57,168,0,0,208,156,0,0,0,224,0,129,2,0,0,0,228,0,0,32,0,224,0,224,57,168,0,0,4,20,0,32,255,78,0,0,165,165,165,165,165,165,165,165,165,165,165,165,71,61,0,0,165,165,165,165,165,165,165,165,156,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,79,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,15,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,207,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,143,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,78,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,14,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,206,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,165,116,24,0,32,236,56,0,32,176,77,0,32,0,0,4,0,104,24,0,32,0,0,0,0,220,24,0,32,224,25,0,32,130 (22:51)
version: 7.17.2.1 (22:51)
frequency: EU (22:15)
deviceRelaxDelay: 3 (22:15)
pauseSending: 0 (22:15)
promiscMode: false (22:15)
statistics: None (22:15)
backgroundRSSI: None (22:15)
channel1: 155 (22:52)
channel2: 151 (22:52)
channel3: 151 (22:52)
RFTxFrames: 1 (22:46)
RFTxLBTBackOffs: 0 (22:46)
RFRxFrames: 0 (22:46)
RFRxLRCErrors: 0 (22:46)
RFRxCRC16Errors: 0 (22:46)
RFRxForeignHomeID: 0 (22:46)
priorityRoute: None (22:15)
dstNodeId: None (22:15)
routeType: None (22:15)
speed: None (22:15)
hops: None (22:15)
jammingDetection: None (22:15)
ch1Threshold: 127 (22:15)
ch2Threshold: 127 (22:15)
ch3Threshold: 127 (22:15)
detected: 0 (22:15)
homeName: (22.08.2020)
homeNotes: (22.08.2020)
S2RequireCSA: false (22:15)
smartStart: None (22.08.2020)
requestFrom: 55840-55798 (22:21)
dskProvisioningList: ****-****masked (21:47)
includingDSK:***,*** masked (22:21)
S2AutoInclude: None (22:15)
pin: None (22:15)
keys: None (22:15)
longRange: None (22:15)
enabled: false (22:51)
channel: None (22:15)
inclusion: None (22:15)
Re: ZWay/Razberry 7 pro crashing on semi-included device
Hello! We are testing a new firmware that should fix this bug. To heal it try to update routes to all nodes - this should help
CorC
Post by CorC »
Thanks PoltoS! That fixed the issue!
emmafrost1
Post by emmafrost1 »
Same issue, updated routed, now working fine
Exploring the world of home automation, one Z-Wave device at a time!
Please upgrade the firmware to 7.36
jimummy989
Post by jimummy989 »
pikashow
ppsspp emulator
Have you upgraded to 7.36 firmware version?
