Razberry Pro Firmware / SDK
micky1500
Re: Razberry Pro Firmware / SDK
Post by micky1500 »
I have 6 Danfoss Radiator valves.
Only 1 has issues, it's not far away, but struggles to connect, maybe interference.
My Job queue is empty.
I noticed that after 4.0.1 that more features are supported.
It now sends the time and date to the Danfoss device. (did not do that with 3.3)
Re- Interview them !
Raspi 4 - (Buster - 32 Bit) Zwave Version 4.1.1, Raz 7 Pro, Serial API Version: 07.38
herbert-f
Post by herbert-f »
Hi Polto,
I need a resolution for downgrade from 7.36 to 7.28. The new version don't work every 10-25 hours and only a cold reboot (no voltage at raspberry) solved the problem.
Please send me the log so we can check it.
lp2067
Post by lp2067 »
Same for me. After upgrade to 7.36 I have strange "Node xxx CRC16: Packet CRC error..."
Have to cold boot every day.
How to downgrade?
The "Node xxx CRC16: Packet CRC error..." appears when corrupted packet arrives. This means your device is too far or some noise mangles it. Z-Way found the issue and dropped the packet. This is the correct behaviour and firmware downgrade could not help here.
lp2067
Post by lp2067 »
After cold boot everything runs perfectly for next 12-24h, affected devices aren't closer then.
CorC
Post by CorC »
I have the same issue ever since the upgrade to the new firmware.
Need to do a full power off to restore functioning, reboot won’t cut it.
If you are interested in logs please let me know which ones you are interested in.
thaui
Post by thaui »
How can I upgrade my Razberry 7 pro to 7.38 and the new SDK? Z-way is showing you have the latest firmware which is 7.36
ScottR
Post by ScottR »
@Thaui
Type in "all" in the access token section. You should see the 7.38 version.
harre
Post by harre »
My network is stable now with latest zway 4.1.1
My events fire like they have done for years and no longer long queue
