I've just received an invalid temperature value from the Fibaro motion sensor (FGMS-001). Image attached.
I have searched google and seems that the sensor is reporting the value correctly. Any clue of where the error come from?
Thank you
Fibaro temperature error
- Temperatura fibaro error.png (10.4 KiB) Viewed 10854 times
Re: Fibaro temperature error
Updated again with a wrong value. Any suggestion?
Thank you
Thank you
- Temperatura fibaro error 2.png (5.21 KiB) Viewed 10848 times
Maybe temperature offset?
Thank you for the reply. They all have default values.
Is there any interesting log that I can share to help debugging?
Did you try to re-include device?
Can you please check Parameter 66 value in Expert Menu?
Thank you IgoriokLT,
I checked and it has the value 64536 (minimum value). I don't understand this value as I never changed it.
