pierre2302
Post
by pierre2302 »
Hello
I create an xml file for a missing module in the database.
I would like to know how to know the values to put for:
<deviceData>
<manufacturerId value="0159"/>
<productType value="0004"/>
<productId value="0081"/>
<libType value="03"/>
<protoVersion value="03"/>
<protoSubVersion value="1c"/>
<appVersion value="01"/>
<appSubVersion value="0c"/>
<basicClass value="04"/>
<genericClass value="10"/>
<specificClass value="01"/>
<optional value="true"/>
<listening value="true"/>
<routing value="true"/>
<beamSensor>0</beamSensor>
<rfFrequency>EU</rfFrequency>
</deviceData>
are these values important ?
Thank you
Post
by PoltoS »
Press a button Create ZDDX on the device Config page and all those will be filled automatically.
pierre2302
Post
by pierre2302 »
For the commandclass I used the documentation builder, but I guess it is also preferable to use ZDDX code creator ?
Thank you
Post
by PoltoS »
Yes, the builder does most of the work for you. You just need to fill association names, config params and generic text description
pierre2302
Post
by pierre2302 »
ok thank you
I created the xml file for the module QUBINO ZMNHJD1. Do you want to add it to the ZDDX list ?
pierre2302
Post
by pierre2302 »
I edited the xml files for devices: Neo Coolcam NAS-SC01Z, Neo Coolcam NAS-WR01ZE and Qubino ZMNHJD1.
I added them with the command:
cd /opt/z-way-server/ZDDX
sudo python ./MakeIndex.py
Everything works fine but since I upgraded to v3.0.0-rc16 nothing appears in the interview tab for these 3 devices.
- Sans titre.jpg (95.65 KiB) Viewed 10582 times
Xml file:
<?xml version="1.0" encoding="utf-8"?>
<ZWaveDevice xmlns="http://www.pepper1.net/zwavedb/xml-schemata/z-wave" schemaVersion="2">
<descriptorVersion>1</descriptorVersion>
<deviceData>
<manufacturerId value="0258"/>
<productType value="0003"/>
<productId value="1087"/>
<protoVersion value="04"/>
<protoSubVersion value="05"/>
<appVersion value="03"/>
<appSubVersion value="5e"/>
</deviceData>
<deviceDescription>
<description>
<lang xml:lang="de"></lang>
<lang xml:lang="en">Power plug is an intelligent device that can be controlled remotely by the Z-wave</lang>
</description>
<wakeupNote>
<lang xml:lang="en"></lang>
</wakeupNote>
<inclusionNote>
<lang xml:lang="en"> Quickly, triple click the code button, the device will enter inclusion mode, and the LED light will flash red and yellow five times .</lang>
</inclusionNote>
<productName>NAS-WR01ZE</productName>
<brandName>Neo CoolCam</brandName>
<productCode>NAS-WR01ZE</productCode>
<productVersion>3.94</productVersion>
</deviceDescription>
<commandClasses>
<commandClass id="0020" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0025" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0027" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0032" version="4" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0059" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="005a" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="005e" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0070" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0073" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0085" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0086" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
<commandClass id="0072" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
</commandClasses>
<assocGroups>
<assocGroup number="1" maxNodes="5">
<description>
<lang xml:lang="en">Group 1</lang>
</description>
</assocGroup>
<assocGroup number="2" maxNodes="5">
<description>
<lang xml:lang="en">Group 2</lang>
</description>
</assocGroup>
<assocGroup number="3" maxNodes="5">
<description>
<lang xml:lang="en">Group 3</lang>
</description>
</assocGroup>
</assocGroups>
<configParams>
<configParam number="1" type="constant" size="1" default="01">
<name>
<lang xml:lang="en">Meter Report Enable.</lang>
</name>
<description>
<lang xml:lang="en">This parameter defines Disable/Enable meter report measure data to controller.</lang>
</description>
<value from="00" to="00">
<description>
<lang xml:lang="en">Disable Report</lang>
</description>
</value>
<value from="01" to="01">
<description>
<lang xml:lang="en">Enable Report</lang>
</description>
</value>
</configParam>
<configParam number="2" type="range" size="2" default="012c">
<name>
<lang xml:lang="en">Meter Report Interval.</lang>
</name>
<description>
<lang xml:lang="en">This parameter defines interval time (in seconds) that Meter report data to main controller.</lang>
</description>
<value from="0000" to="ffff" unit="1s">
<description>
<lang xml:lang="en">default 300 (=300sec)</lang>
</description>
</value>
</configParam>
<configParam number="3" type="range" size="1" default="0d">
<name>
<lang xml:lang="en">Configure maximum over-load current.</lang>
</name>
<description>
<lang xml:lang="en">If the current consumed by load greater than maximum current, the plug will cut off power.</lang>
</description>
<value from="00" to="10" unit="1A">
<description>
<lang xml:lang="en">default 13 (=13A)</lang>
</description>
</value>
</configParam>
<configParam number="4" type="range" size="1" default="0c">
<name>
<lang xml:lang="en">Configure maximum Alarm current.</lang>
</name>
<description>
<lang xml:lang="en">The plug will send over-current notification to main controller and the LED will be turn RED, but plug cannot cut-off power. This value must be less than parameter 3#.</lang>
</description>
<description>
<lang xml:lang="en">default 12 (=12A); 1 - parameter #3.</lang>
</description>
</value>
</configParam>
<configParam number="5" type="constant" size="1" default="01">
<name>
<lang xml:lang="en">Led Display Enable.</lang>
</name>
<description>
<lang xml:lang="en">This parameter defines the LED indication Function ON/OFF</lang>
</description>
<description>
<lang xml:lang="en">Disable LED</lang>
</description>
</value>
<description>
<lang xml:lang="en">Enable LED.</lang>
</description>
</value>
</configParam>
<configParam number="6" type="range" size="1" default="05">
<name>
<lang xml:lang="en">Configure power report.</lang>
</name>
<description>
<lang xml:lang="en">This parameter defines by how much power consumed must change to be reported to the Z-Wave Controller.</lang>
</description>
<value from="01" to="64">
<description>
<lang xml:lang="en">default 5 (=5%)</lang>
</description>
</value>
</configParam>
<configParam number="7" type="constant" size="1" default="01">
<name>
<lang xml:lang="en">Remember Relay ON/OFF status</lang>
</name>
<description>
<lang xml:lang="en">This parameter defined the relay status if remember or not.</lang>
</description>
<description>
<lang xml:lang="en">Don’t Remember, the relay will keep OFF when Plug Supply Power</lang>
</description>
</value>
<description>
<lang xml:lang="en">Remember the Relay Status.</lang>
</description>
</value>
</configParam>
<configParam number="8" type="constant" size="1" default="00">
<name>
<lang xml:lang="en">Configure Plug Time switch Function.</lang>
</name>
<description>
<lang xml:lang="en">This parameter defines the timer function Enable/Disable.</lang>
</description>
<description>
<lang xml:lang="en">Time switch Disable.</lang>
</description>
</value>
<description>
<lang xml:lang="en">Time switch Enable.</lang>
</description>
</value>
</configParam>
<configParam number="9" type="range" size="2" default="0096">
<name>
<lang xml:lang="en">Configure Time switch Period</lang>
</name>
<description>
<lang xml:lang="en">This parameter defines the time period that plug time switch off. The relay will be turn-off after delay this parameter.</lang>
</description>
<value from="0001" to="ffff" unit="minutes">
<description>
<lang xml:lang="en">default 150 (=150min)</lang>
</description>
</value>
</configParam>
<configParam number="10" type="constant" size="1" default="01">
<name>
<lang xml:lang="en">Button On/Off enable</lang>
</name>
<description>
</description>
<description>
<lang xml:lang="en">Disable button.</lang>
</description>
</value>
<description>
<lang xml:lang="en">Enable button.</lang>
</description>
</value>
</configParam>
<configParam number="11" type="constant" size="1" default="00">
<name>
<lang xml:lang="en">Clear accumulated energy.</lang>
</name>
<description>
</description>
<description>
<lang xml:lang="en">Disable clear accumulated energy.</lang>
</description>
</value>
<value from="ff" to="ff">
<description>
<lang xml:lang="en">Enable clear accumulated energy.</lang>
</description>
</value>
</configParam>
</configParams>
</ZWaveDevice>
What's the problem ?
pierre2302
Post
by pierre2302 »
It is this information that no longer appears.
- Capture.PNG (32.05 KiB) Viewed 10487 times
