Interview failed with Philio PST02-1A
michap
Re: Interview failed with Philio PST02-1A
Post by michap »
PoltoS wrote:@michap
You are using UZB without license loaded? It clearly does not support some features.
No, use UZB with license (integrated, purchased UZB stick with license)
BTW: is it possible to check the license in software (or log) ?
Michael
ByteCoder
Post by ByteCoder »
Has anybody a solution for this problem?
or same status here?
does anybody know where i can find firmware updates for the philio device ?
michap
Post by michap »
if you have problems, try to include the device in Expert mode (Network - control) - with "Unsecure" option.
It should work.
Michael
Hello, all!
Philio team helped us to find a very rare issue in Z-Way that results in Association not set in Philio devices during interview process. Also last steps of interview might be incomplete. This means you need to manually associate group #1 to device 1 (RaZberry) and manually wake up the device. This happens only if there are quite a lot of devices in the system and Security is used.
We are fixing the problem, but manual association is a possible workaround for the moment.
Once fixed (will be in 2.1.2-rc10) we will try to collect again your feedback to make sure it works.
Pierre
Post by Pierre »
After first getting a Gen 3 Razberry I now own the 5th Gen.
My only sensor is the PST02-1A, and I simply could not add it to the UI Interface.
My PST02 is reported as Application version 1.16
Running a Firmware Update from SDK 6.51.03 -> 6.51.05 and Serial API 05.00 -> 05.04, I it seemed to work better, but the whole "Add Device" always fails and does not complete the interview. After which I end up with lots of duplicate devices, which I only figured out to remove by using "Controller Factory Default".
Besides those problems, one I just encountered is the Association Groups.
It reports: "Number of assoctiated nodes have reached the maximum allowed number"
This sounds as if either the Razbery or the PST02 has reached it's maximum.
How can I clear it and receive a correct association?
Thank you!
Pierre
Post by Pierre »
In case my message for lost in the wave:
1. Are there any issues with the PST02-1A and Z-Way?
2. What is the meaning of "maximum number of allowed nodes" and how can it be resolved?
Thank you!
Restart interview to solve it. It means the size of Association group is full
