hello
I installed the smoke detector FSS 001,the temperature is displayed but nothing against the smoke . How to have the state feedback ?
thank you
Fibaro FSS-001
pierre2302
Fibaro FSS-001
Re: Fibaro FSS-001
This device uses Alarm CC. We are working to make it work in latest versions.
pierre2302
Re: Fibaro FSS-001
thank you poltoS, hoping you'll get there soon
Re: Fibaro FSS-001
Any news from this?
Neither smoke alarm nor temper alarm outputs anything in any way.
The FSS-001 also have a "black box recording" which I'm not sure what it is and how it's supposed to work, starting to log smoke levels before the alarm is triggered.
Re: Fibaro FSS-001
Actually I get alarm readings fine, although I have only tested the tamper alarm "General Purpose Alarm". Heat and Smoke alarms show up as well.
I'm not sure if I see any smoke readings. Will do a smoke test at some point later.
Re: Fibaro FSS-001
Just added AlarmSensor in v2.0.1-rc2
Re: Fibaro FSS-001
I saw, great. (I'm actually mainly using the JSON interface, and that worked since v2.0.0. I also wrote a backend to SMS me on these events.)
I still don't know how the "smoke level" logging is supposed to work, but I'll try with some smoky burning newspaper some other day.
edit: Where can I see "AlarmSensor" in the interface? I can't find it anywhere in rc7 (which I presume will have that as well), neither /expert nor /blueui. It might be in the home automation, but I haven't learned how to navigate that.
pierre2302
Re: Fibaro FSS-001
- Sensors (Generale purpose alarm / Smoke / Heat) ghost appearing with the expert interface. Against only by the temperature with blueui
- Too bad there is still no sensor (idle / triggered) that informs the detector status
Z way version 2.0.1-RC12
pierre2302
Re: Fibaro FSS-001
The same problem as the KFOB Zwave me always no return of state JSON.
I hope that the update will soon arrive, her this kept waiting!
At present unusable with openremote!!
